Author Topic: K04 conversion parts list  (Read 2543 times)
Offline mar_k
« on: 28 April 2013, 18:04 »
My mate is converting his AUM to K04, I have used the search function but would still like some help please.
He has got:
KO4 turbo
4 injectors
Manifold
injector rail
Oil cooler
Oil feed pipes
what else will he need?
Engine Loom?
Who supplies K04 downpipes for golfs?
Offline turbokid23
Re: K04 conversion parts list
« Reply #1 on: 28 April 2013, 18:15 »
Don't need wire loom mate, down pipe look for a s3 down pipe, k04 tip, Fmic, and a trip to Rtech
Offline Chris#101
« Reply #2 on: 28 April 2013, 20:07 »
Rods  :wink:
          2003 1.8T: R-tech Live Cutom Stage 2 remap: N249 Bypass : Forge T.I.P : Forge 007p  : Forge Actuator, yellow spring : Toyosports F.M.I.C : Toyosports C.A.I :        PCV simplified - oil catch can : 42' Draft 3" turbo back non res exhaust system : Devils own W.M.I : 231bhp & 258lbs-ft
Offline asboGTI
« Reply #3 on: 28 April 2013, 20:14 »
vw golf mk4 ARZ 1.8T pipercross panel filter, xenon headlights, JOMS coilovers, forge 007p with green spring, audi tt anti roll bar, 3inch ebay trubo back exhaust, COOKIES MONSTER STICKER(adds bhp I swear)
Offline mar_k
« Reply #4 on: 28 April 2013, 21:02 »
Yep, Rods will be going in.
The car is in bits at the moment. I removed the head from it last week as it has a bad oil leak between the head and block.
He will be sourcing an AGU head to put on.
Since its all apart it would be rude not to upgrade.
He was selling the car but since finding a few problems with it he has decided to keep it and build it up again.
I will get some pictures of the progress.
Offline Chris#101
« Reply #5 on: 28 April 2013, 22:48 »
Tbf if your going down the k04 + rods route you might aswell go all out to unleash full power and get
Relentless tubular manifold
Devils own WMI
Offline Ashmond
  • Money, b!tches And Boost
« Reply #6 on: 29 April 2013, 10:08 »
My KO4 boost killed my AUM engine - +1 on rods
Offline mar_k
« Reply #7 on: 29 April 2013, 17:05 »
I have mentioned the relentless manifold to him, Not sure if he will listen though.
One question, What happens with the EGT sensor and wiring?
The k04 on my LCR has one fitted but how does this get wired into the golfs loom?
Offline xionsolaris
« Reply #8 on: 29 April 2013, 22:10 »
Am i missing something why agu head is it better or is it the cable throttle
Offline Chris#101
« Reply #9 on: 29 April 2013, 22:37 »
Abu is a large port head :wink:
