Author Topic: Ford recaros into mk3  (Read 3339 times)
Offline Jamesimp
« on: 26 April 2013, 22:56 »
Has anyone fitted ford recaros into a mk3? I've done a in depth search and got no where, but i might have missed it.
I've got a set for nothing and really wanna fit them. They have the extending base.
Re: Ford recaros into mk3
« Reply #1 on: 26 April 2013, 23:50 »
Your going to need to weld the bases to the mk3 subframe
Offline barrym381
« Reply #2 on: 27 April 2013, 00:53 »
seen then in a mk2 but only the fronts  :smiley:
Offline tshirt2k
  • Been there...Done that...
« Reply #3 on: 27 April 2013, 07:30 »
You will have to adapt the frames from you existing or another set of seats to get them to fit. Will involve cutting and welding.
Mk3 ABF 16VT Megasquirt V3
Offline tweed
« Reply #4 on: 27 April 2013, 11:39 »
Lovely seats not far off the mk3 recaros so be really nice when fitted.
Do it! Do it!
Offline robjackson
« Reply #5 on: 27 April 2013, 14:36 »
Iv had XR3i 'wingback' recaros into a sierra by having the moving parts/ frames cut out and re-welded,
Perfect fit,
And the same with 911S seats into same car.
I had 'chris gilley beetles' do it in manchester for 60qid the pair both times.
He'll also be transfering my wingbacks into my mk3 wagon and the 911's into my B4 wagon
Its reletavly straigt forward, cheap and above all,
AWESOME
Do it, do it!
Offline Jamesimp
« Reply #6 on: 27 April 2013, 17:58 »
Well i stripped the drivers base right down to the frame on a recaro. It doesn't look like it will be to hard. I just need a standard base to ply with now or the time to take mine out and mess.
Offline GOLF-MK3-GTI
« Reply #7 on: 27 April 2013, 18:03 »
There's a set or RS turbo seats on MK2 frames. Check the link out:
item number: 190828042248
looks like it's do-able pal  :wink:
Offline Jamesimp
« Reply #8 on: 27 April 2013, 19:37 »
They are the exact seats i have. Except compared to those mine look brand new! Cannot wait.
Offline Jamesimp
« Reply #9 on: 04 May 2013, 19:14 »
Well fitted the recaros today. They are sat a little high and passenger is a tad close to the centre console. But they are SO comfy! I will alter them at some point to sit lower, but they are mint arm.
