Author Topic: Injector recall problem.  (Read 16856 times)
Offline stevieC
« on: 24 April 2013, 22:04 »
Well the dreaded DPF light has come on 4 days after having the recall done,so took it for a long drive to clear it and light remains on.this would usually have cleared it and have heard horror stories about gt sports running perfect then after recall having problems with the dpf.Try and regen it 2moro and if this does'nt work might have to remove it.
Gtd 3dr candy white,charleston shadows
Offline Rhyso
Re: Injector recall problem.
« Reply #1 on: 24 April 2013, 22:11 »
Oh dear not another one  :sad:
Equally it could be a sensor that has failed. I wouldnt bother trying a regen as you may cause irreparable damage  :sad:
Offline stevieC
« Reply #2 on: 24 April 2013, 22:29 »
what I'm I better doing Rhyso as I've known this car since new &theres been no probs till now.Its also going into a vw specialist on fri to get sportlines fitted and I'll ask them to look at it.they also do custom code bypass and delete what do you think of CC tuning.cheers stevie
Offline Rhyso
« Reply #3 on: 25 April 2013, 07:45 »
Two things for them to check is
A) have the injectors been fitted properly. Lots of reports suggest the seals arent seated correctly
B) that the timing is set correctly
Have a look at this link
http://www.audi-sport.net/vb/a3-s3-sportback-8p-chassis/183040-how-guide-pd-tdi-injector-adjustment-clearance-lash.html
Offline Adam
« Reply #4 on: 25 April 2013, 08:07 »
 :lipsrsealed:
Down Hill From Here.
Offline stevieC
« Reply #5 on: 25 April 2013, 18:37 »
cheers rhyso, thanks for your help will mention this when car goes in, also the car does'nt seem to drive any different with dpf light on, my last gt sport would run rough when light was on.
Offline Rhyso
« Reply #6 on: 25 April 2013, 22:27 »
Is it the DPF light or the engine light?
If its the latter it could be a throttle body / EGR problem. I had a customer with that problem which he ignored and ended up killing his DPF  :rolleyes:
Offline stevieC
« Reply #7 on: 26 April 2013, 17:02 »
Rhyso car now has dpf light & coil light on & it's went into limp mode.not sure what to do as the injector recall was done in Newcastle & I'm up in glasgow so impossible to take it back to them.
Offline stevieC
« Reply #8 on: 26 April 2013, 17:21 »
Forgot to say engine management light is also on,could there be damage to the engine.
Offline Rhyso
« Reply #9 on: 26 April 2013, 18:14 »
Injector is a warranty issue so just take it to your local dealer
All the lights on means you've won the jackpot  :laugh:
