Author Topic: GOLF MK4 GTI. Slow when up to temp  (Read 1406 times)
Offline kingaz
« on: 23 April 2013, 21:32 »
My car is nippy until the temp hits 90. The trip conp goes blurry and it drives slow. Got dicked by a diesel the other day. Any ideas?
Offline navmk4gti
Re: GOLF MK4 GTI. Slow when up to temp
« Reply #1 on: 23 April 2013, 23:00 »
Scan it for fault codes first. Can be number of things
Offline kingaz
« Reply #2 on: 24 April 2013, 01:36 »
Already scanned mate. No fault codes
Offline Dalo Harkin
« Reply #3 on: 24 April 2013, 07:03 »
Lol.....
Start with the basics, if the trip goes blurry check power, battery etc
I never ever drive mine hard until it's up to temp because before that you run the risk of damaging parts
Offline kingaz
« Reply #4 on: 24 April 2013, 12:39 »
Yeah but the trips fine up until it gets to temp. Might be coincidence. Had a mate check wiring etc. He cant find nothing wrong there.. i dont drive mine hard cold but u can notice the difference ALOT. Had a suggestion my air filter could be suckin thw warm air from the engine bay...sound possible?
Offline Chris#101
« Reply #5 on: 24 April 2013, 18:43 »
Few more suggestions
blocked intercooler?
rubber intake/charge pipe hoses collapsing under load?
          2003 1.8T: R-tech Live Cutom Stage 2 remap: N249 Bypass : Forge T.I.P : Forge 007p  : Forge Actuator, yellow spring : Toyosports F.M.I.C : Toyosports C.A.I :        PCV simplified - oil catch can : 42' Draft 3" turbo back non res exhaust system : Devils own W.M.I : 231bhp & 258lbs-ft
Offline xionsolaris
« Reply #6 on: 24 April 2013, 18:49 »
I would drive with vag com on live data from cold to warm to see if any readings are fluctuating
Offline JimBR
« Reply #7 on: 25 April 2013, 14:41 »
Diesels are faster than people think. If your 1.8T is standard I'd fancy my chances in my Fabia VRs. If both cars are mapped I still think it would be a similar story.
