Author Topic: camshaft position sensor  (Read 870 times)
Offline Mcleod
« on: 23 April 2013, 21:22 »
Hi all
I have a problem with my girlfriends mk4 2.0 8v gti. When driving the car cuts out then comes back to life every couple of feet, i had the car tested and it came back with a fault with the camshaft position sensor.
Might be a stupid question but where is this sensor on this car. I have had a look for it without much luck.
« Last Edit: 23 April 2013, 21:39 by Mcleod »
Offline dom
  • Back in a Mk4
Re: camshaft position sensor
« Reply #1 on: 23 April 2013, 21:26 »
I had a faulty sensor on my Mk3 a few years ago, IIRC the sensor was part of the distributor cap, got no idea if it's the same on a MK4.
Offline Mcleod
« Reply #2 on: 23 April 2013, 21:32 »
I dont have a clue where it is lol, there is a sensor behind the distributor cap but its not attached to it its attached to the engine block. If someone had a picture of where this is located would be a massive help.
Offline itavaltalainen
« Reply #3 on: 23 April 2013, 21:37 »
camshaft position sensor..... not gonna be in the oilpan is it?
 have a look around the cylinder head....
Offline Mcleod
« Reply #4 on: 23 April 2013, 21:49 »
There is a sensor on the bottom of the oil pan but i though that would be for the oil and not the camshaft, i though it would be nearer the camshafts then the oil pan.
Offline welshdean
« Reply #5 on: 23 April 2013, 22:10 »
The camshaft positioning sensor is behind the cam gear, a pain in the arse to get to as belt needs to come off . Mine also needed replacing
