Author Topic: CAM CHAIN ?  (Read 4644 times)
Offline Jumbojim
CAM CHAIN ?
« on: 23 April 2013, 09:52 »
Gentlemen
I have heard that some GTI 147KW engines from 2008 onwards have a cam chain fitted instead of the short life tooth belt.
Could this really be true, and could my BWA coded engine be one of them?
Offline Chris.
Re: CAM CHAIN ?
« Reply #1 on: 23 April 2013, 13:56 »
Most VW engines were fitted with a chain between cams.
Click For Build Thread
Offline GJSEB79
Re: CAM CHAIN ?
« Reply #2 on: 23 April 2013, 19:27 »
i can also verify that all mk5 have cam chains my is currently been done due to the dreaded diesel knocking from the engine
Offline Philip James
Re: CAM CHAIN ?
« Reply #3 on: 23 April 2013, 22:13 »
You mean a timing chain instead of a timing belt. Yes, the late mk5 gti's have a tsi engine which uses a chain.
Just found the perfect GTi...
Offline Gene Hunt.
Re: CAM CHAIN ?
« Reply #4 on: 10 May 2013, 17:03 »
........really?. my 08 ED30 has a belt.
Candy White ED35.
Offline GJSEB79
Re: CAM CHAIN ?
« Reply #5 on: 11 May 2013, 22:23 »
yes it will have a belt but will also have a chain that drives the inlet cam on top of the engine it is normal the the adjuster unit that is at fault
Offline Gene Hunt.
Re: CAM CHAIN ?
« Reply #6 on: 12 May 2013, 19:43 »
.....yeag i know that,had it replaced on my 05 reg GTI. :smiley: I think in post one he was trying to make the point that the ''main cam drive'' was by chain & not belt. :smiley:
Candy White ED35.
