Author Topic: Forge valve  (Read 1111 times)
Offline daddy5x
  • any time now milltek cat back remap
Forge valve
« on: 21 April 2013, 16:17 »
Hi all I've been given a forge valve by a friend my question is what if   any benefits will I get if I fit it my car is standard
standard gti turbo (aum     4 now
Offline barrym381
Re: Forge valve
« Reply #1 on: 21 April 2013, 16:19 »
none but standard 1s are known to be sh!t  :smiley:
Offline daddy5x
Re: Forge valve
« Reply #2 on: 21 April 2013, 16:46 »
Will there be any different in sound
Offline martinGTT
Re: Forge valve
« Reply #3 on: 22 April 2013, 08:49 »
Not likely... Might be a tiny bit louder.. But not noticeable
Indigo Blue Golf 1.8T AUM
Offline Dalo Harkin
Re: Forge valve
« Reply #4 on: 22 April 2013, 12:58 »
The main benefit is that the original Bosch ones are made from plastic and are prone to cracking.
The forge is metal and you can service it with new springs and shims if needed, also as you add more mods / remap it you can change the spring inside to match the boost requirements
Offline daddy5x
Re: Forge valve
« Reply #5 on: 22 April 2013, 14:14 »
Thx  :smiley:
