Author Topic: What fuel pump and injectors??  (Read 1213 times)
Offline Scott-R
  • GoT BoosT!
« on: 21 April 2013, 11:16 »
What are people running??
My current setup needs some more fuel I'm currently at 227bhp on standard fuel with stage 2 map.
Running the ko4-001 with all mods to go with FMIC,tip, dv, actuator,full exhaust with decat,
See people have Saab red injectors is that with a Walbro pump?
Golf GTI ... What else would you have?
Offline Scott D
Re: What fuel pump and injectors??
« Reply #1 on: 21 April 2013, 15:55 »
auq injectors are good for 260ish
380cc injectors and fuel pump from a BAM 2wd are direct swap parts and a good upgrade if needing more fuel
2003 1.8T GTI 180 - APR Stage I, S2000 Filter, R-Tech Supersize TIP, Bilstein B12 Suspension, 18" OZ Superleggera, Recaro Heated Leathers, US Spec Rear Lights, N249/SAI/PCV Delete
1.8T AUQ - 241bhp & 286 ft-lb
R-Tech Map, Forge FMIC, SFS Oversized TIP, Ported Manifold, Milltek Turboback non res exhaust, Forge 007p, N249 & N112 delete, SAI delete, S2000 Air Filter, Sachs clutch & Lightweight Flywheel
Offline Scott-R
  • GoT BoosT!
« Reply #2 on: 22 April 2013, 06:48 »
I see your spec Scott and my tourqe was about 270.. Why is your below 200??
Offline dom
  • Back in a Mk4
« Reply #3 on: 22 April 2013, 07:21 »
Because it hasn't been mapped yet :wink:
Offline Scott-R
  • GoT BoosT!
« Reply #4 on: 22 April 2013, 16:25 »
So how can he have 210bhp?? Is that a guess? Ha
Offline asboGTI
« Reply #5 on: 22 April 2013, 16:59 »
maybe he hasnt had his extra bits mapped in yet
vw golf mk4 ARZ 1.8T pipercross panel filter, xenon headlights, JOMS coilovers, forge 007p with green spring, audi tt anti roll bar, 3inch ebay trubo back exhaust, COOKIES MONSTER STICKER(adds bhp I swear)
Offline Scott D
« Reply #6 on: 22 April 2013, 20:02 »
still on a stock 180 map, mods are obviously working well for BHP but torque is not that much difference as only running 8-9psi.
dyno tested as suspected MAF was over reading after logging  :grin:
Offline Scott-R
  • GoT BoosT!
« Reply #7 on: 22 April 2013, 20:24 »
Wish I lived near r-tech.
