Author Topic: When do you recommend changing the Cam Belt?  (Read 3021 times)
Offline Jumbojim
« on: 21 April 2013, 10:43 »
2008 GTI 2.0ltr. Turbo
The Bentley Manual says that the timing belt should be changed depending on condition between 80,000 and 120,000 miles.
Do you guys agree with that?
Offline Rhyso
Re: When do you recommend changing the Cam Belt?
« Reply #1 on: 21 April 2013, 11:52 »
Hell no!!
Im sure its 60,000 miles or 5 years. Either way do not let it get to 80,000!!
Change the water pump at the same time too  :wink:
Offline redgem
« Reply #2 on: 13 August 2013, 21:39 »
40,000 miles or 4 years which ever comes first.
Offline dTEA
  • back in an MK5
« Reply #3 on: 24 August 2013, 01:52 »
Pretty sure the 40,000 got lift to 60,000 as Rhyso says, but if you are anywhere near 70,000 do it asap
Edition 30 / T5 T32 Kombi
« Reply #4 on: 28 August 2013, 21:23 »
Get it replaced ASAP around 60k it is due to be changed.
