Author Topic: Irregular RPM MK6 GTI  (Read 2409 times)
Offline Berto89
« on: 19 April 2013, 17:19 »
Someone has already had minimal problems that remain high for a few seconds on the 2.0 TSI?
On older TFSI know it was a problem of PCV, perhaps also of course MK6 is the same problem ...
The symptom is this, the minimum right away should not be at 800 rpm but remains erratically to 1200 and then declined, while on the move if you put the car in N does not go to 800 but is still around 1200 rpm:
http://www.youtube.com/watch?feature=player_embedded&v=iqo2VWlsqfI
I think the items damaged is this:
Problem think is big pressure of K04, i think..
Offline Berto89
Re: Irregular RPM MK6 GTI
« Reply #1 on: 20 April 2013, 11:26 »
THese are the errors appear:
Offline mike.
« Reply #2 on: 20 April 2013, 11:38 »
Here are explanations of each of those error codes on the Ross-Tech site
Error P2279
Error P0441
Error P0171
« Last Edit: 20 April 2013, 11:40 by mike. »
Mk6 GTI 3dr | DSG | Tornado Red | 18" Monza 2 | LED Xenons | RNS510 | Bluetooth | Smoked LED tails | Cruise | Reversing Camera | TPMS | - now sold :(
Offline Berto89
« Reply #3 on: 27 April 2013, 09:03 »
Finally solved, when installed K04 not connected a tube from turbocharger to aspiration collector:
Now is all oK!
Offline Obbzi
« Reply #4 on: 28 April 2013, 23:48 »
Glad you got it sorted out and all working :smiley:
2008 R32 DBP gone. 2008 GT TDI going 2009 GTI coming soon!
Offline Berto89
« Reply #5 on: 29 April 2013, 08:55 »
Finally yes, so started try chip k04:
http://www.youtube.com/watch?v=59Y8AufNQvU
