Author Topic: Bypassed my n249 however.........*Worrying issue, need your input please*  (Read 13414 times)
Offline GTi_James
o dear mate lol, like said it could be nothing but too much pressure for the DV to take straight away, tried twisting the DV about yet? may be worth a shot?
Offline Nino
not yet i will drive it gentle to work tomorrow and hope shes ok.
Current - MK6 GTi Edition 35
Offline Scott D
pointless reversing the DV
doesn't look right how you've bypassed it as from what I remember when doing it (and this was 3ish years ago) all the hoses under the cover near inlet manifold are no longer used only the valve plugged in to prevent fault codes and blanking plugs on the TIP.
this looks similar to how it looked after the guide I used
2003 1.8T GTI 180 - APR Stage I, S2000 Filter, R-Tech Supersize TIP, Bilstein B12 Suspension, 18" OZ Superleggera, Recaro Heated Leathers, US Spec Rear Lights, N249/SAI/PCV Delete
1.8T AUQ - 241bhp & 286 ft-lb
R-Tech Map, Forge FMIC, SFS Oversized TIP, Ported Manifold, Milltek Turboback non res exhaust, Forge 007p, N249 & N112 delete, SAI delete, S2000 Air Filter, Sachs clutch & Lightweight Flywheel
Offline Nino
Offline golfyste
  • Project track car
What is your boost gauge doing?
Have you got the non return valve the right way round?
Offline Nino
Boost gauge is how it was before if anything its showing that boost is holding rather than falling off and yep dwfo the correct way round
Offline golfyste
  • Project track car
When you let off is the pressure dispersing straight away?
Any kinked pipes?
If you don't have you sai or anything like tht you don't need that metal plate
I removed that and all the hard lines that you said you capped. Tidies up the bay nicely!
Offline nickellis1
Sounds like turbo flutter.. I had this when my Bosch valve had failed, so because it wasnt dumping the air correctly it was causing the turbine in the turbo to stall which cAuses it to shudder making the fluttering noise, I then fitted my 007p with yellow spring and this rectified my issue
Eventually this issue will cause your turbine to fail and kill your turbo...
Offline Nino
Hmmmm maybe i should change my spring from green to yellow? I noticed today while driving to work under low pressure the DV sounded how it should and would only flutter if i boosted 5+ psi
All pipework is fine btw  :undecided:
Offline GTi_James
change the spring then pal, as it looks like more boost is getting to the DV maybe uprating the spring would rectify this? strange how my standard DV didnt do this though
