Author Topic: Golf plus on eBay low price due to engine management light on  (Read 2044 times)
Offline Mk2_tel
What would be the worse case scenario?
Had new Cambelt etc now on 147k 2005 plate
Offline GJSEB79
i went to see a golf with managment light on and could be numerous things but it was the timing out due to time chain slack which was an expensive job
Offline Rhyso
What engine?
Offline Mk2_tel
2.0 tdi 140 gt
Offline Rhyso
Could be a clogged / faulty EGR valve
Without seeing or driving the car its a little hard to guess  :undecided:
Got a link to the ad?
Offline Mk2_tel
That wouldn't be to sad if it was that.
eBay number is 321106901299
Offline andyr
I would say be vary wary! The dealer is obviously VW/Audi savvy being that all bar 1 of his/their stock is VW derived. I'd think that they have a fair idea of what's wrong and know it's going to be expensive to fix.... And remember you'll have no comeback as they've stated the car has a 'problem'.
If it's a BKD engine (and it probably is) be advised that the 'early' models head's are renown to go porous - there are 3 versions and the first 2 could prove... shall we say.... troublesome (ie, junk!)..... If you go for a looksee then at the very least check the water for clarity with no 'mayo' in it or under the oil filler cap and try to see if there is white smoke from the exhaust, trouble is (As Rhyso says) it 'could' just be the EGR valve and that could well show the same signs as a porous head (mayo/cloudy water/white smoke). No real way of checking porousity for sure without removing it and having it pressure tested properly!
Or.... It could just be both of the brake lights blown!!! (but we all know it isn't eh?)
Mk VI Black Pearl GTD.... No Frills, replaced a Black Pearl PD150 Bora, which in turn replaced a Dragon Green VR6 which followed a Dusty Mauve MK III 8v Gti.
