Golf mk4
Wazzzer
Gearbox stub axle oil seal
Topic: Gearbox stub axle oil seal (Read 919 times)
mar_k
18 April 2013, 09:51 »
My mates 1.8t has decided to push the oil seal out a little which has caused the oil to leak out of the gear box.
How easy is it to replace the seal?
Marktwo8v
Re: Gearbox stub axle oil seal
18 April 2013, 16:34 »
The big black seal on the passenger side?
That means the bearing seat is goosed, box needs a rebuild.
Is his clutch pedal dropping an inch or two as well?
mar_k
19 April 2013, 20:24 »
Its on the drivers side, The seal behind the drive shaft flange.
The pedal doesn't drop but you can feel a bit of vibration on it.
Golf mk4
Wazzzer
