Author Topic: One pot oil pressure question  (Read 1469 times)
Offline golf-sib
  • Турботазик
« on: 18 April 2013, 01:16 »
Right, I'm planning to fit an oil cooler to a 1pot engine, to increase oil capacity and to maintain oil temperatures. My idea is to take a pickup off the oil filter and block the return as this is the only place I know where engine pressure would be high, even though the pressure won't be that great on a small motorcycle engine. Any idea's where typically high oil pressure would be located and where I can return as a generic question?
I've not taken the engine apart nor I plan too, but I'm just needing generic guidance from people with experience as mr google is no help when you ask about oil pressure generically.
Thanks in advance.
VW Golf - k03 AGU - 200BHP
1.8T AGU..
R135
  24
Offline danny_p
Re: One pot oil pressure question
« Reply #1 on: 18 April 2013, 22:52 »
small engines are quirky things
it may not een have a pumped oil system and rely on splash lube or some fore of assisted splash lube.
if its got an oil filter tho it likely dose have pumped oil the oil filter is usally te easyest place to breack into the pumped oil system on extrenal filter setups its about as easy as it gets you just buy or make a sandwich plate  on internal filter setups it can be a right twerp, you may end up converting to external filter
all the VW's have gone bar 1.
Offline golf-sib
  • Турботазик
« Reply #2 on: 19 April 2013, 09:57 »
From what I have found is, its a Honda replica with OHC unlike its predecessors which were OHV setups. It does have a tiny internal pump producing around 4~5 psi to shift the oil when warmed up, I'm guessing its a impeller type running off the gearbox or another internal system.
It doesn't have a real oil filter in terms of a paper type, it has a strainer (mesh) filter in place. Some of the kits I've seen cap the return at the strainer and place an external oil filter of the same type and feed back in after the cooler but this is all on the OHV. My main concern on this engine being a OHC is whether the return goes to the rocker to splash the cams, its hard to judge without physically taking the engine out and apart. Usually there's a bolt somewhere for a return on the side of the engine but I've yet to spot one. As typically they use the same parts for the 125, 150, 200cc just the heads vary, but the OHC variation is their latest creation so no ones really tried much, I know the 200cc has variation has a oil cooler as stock but without many images or schematics I cannot tell where or how the manufacturer does it.
My idea was to pick up off the strainer, block return on strainer, supply oil cooler and the return part I'm struggling on...... Maybe feed to rocker or back into where you top up oil as that will be low pressure, but my concern is where the return goes encase it does keep another part of the system lubed. Maybe not block the return and just split the oil strainer two ways, if this is an option would oil pressure be significant.
Any more input is appreciated.
1.8T AGU..
R135
  24
Offline danny_p
« Reply #3 on: 19 April 2013, 20:49 »
i would feed the oil back into the return from the filter ,  as you said without more info doing anything else chould be risky
