Author Topic: Limp mode????  (Read 3262 times)
Offline alex160
Limp mode????
« on: 16 April 2013, 20:40 »
Was driving my car back from work today and got to the dual carriage way which is an up hill job, any way gave the car some beans in 5 gear upto around the 70mph mark ;) and all of sudden lost virtually all boost from my turbo, no lights up or anything but flat as a turd, got home and plugged my vag code reader on an got the code 17965. Apparently this could be a hose/ connection or n75 valve fault.
When I got the car I noticed that the top intercooler hose connection had been cable tied up so I'm guessing this could be at fault, is it worth replacing that pipe with this: http://item.mobileweb.ebay.co.uk/viewitem?itemId=170989776969&index=16&nav=SEARCH&nid=62550616290
I cleared the code and went for a quick spin up the road and car was fine again, so only happens when under a lot of load.
Thanks
2001 Golf GT TDi  150bhp/ 250 ftIb torque  *No smoke, No poke*
Jamex coilovers, 8k HID's, 18" RS6 alloys, Pipercross panel filter. Stage 1 Revo remap.THS FR3 engine mounts, Anniversary headlamps. GTI rear spoiler, Miltek largebore decat/downpipe, Pro-speed cat back exhaust system (V6 4mo style tailpipes) *SOLD*
2002 Golf GT TDi 130. Allard egr removal kit, 18" Audi rs6 alloy wheels. Mk5 rear aero wiper.gen R32 roof spoiler, JOM coilovers, JOM heavy duty adj droplinks
Offline scarr89
  • Mk4 Golf, DERV FTW!
Re: Limp mode????
« Reply #1 on: 16 April 2013, 20:53 »
Yes, especially in 5th gear at those speeds up hill. Drop it down and the engine won't be labouring as much so you shouldn't request so much boost which shoulnd't put you in limp mode, that make sense?  :huh:
Yes that pipe is a good upgrade, can be DIYed for cheaper.
http://uk-mkivs.net/forums/t/413937.aspx?PageIndex=1
That is a guide for the whole IC upgrade, which could be done for the cost of that one pipe. If you just do the pipe you could do it far cheaper on your own. Also...EGR deletes can be had for like £40ish 2nd hand...get one second hand.  :smiley:
Offline alex160
Re: Limp mode????
« Reply #2 on: 16 April 2013, 21:26 »
Thanks for advice, had to use 5 gear though due to speed I was doing if you get me ;)
I already have an allard egr delete kit installed but will defo check out the DIY upgrade :) thanks
Offline scarr89
Re: Limp mode????
« Reply #3 on: 16 April 2013, 21:54 »
You said you were doing 70mph  :rolleyes:
I'd say 5th is a good 70mph up hill gear; but not for getting to 70 going up a hill, IMO.
