Author Topic: Tyres on 17's  (Read 2681 times)
Offline barelyhuman
  • CoNfOrMiTy Is A cRiMe :)
Tyres on 17's
« on: 15 April 2013, 22:20 »
Hi guys, my new Golf Gti is currently running 205 40 17's which were fitted by the previous owner, and it tends to wander all over the place, and when its wet it aqua planes something chronic :shocked: ! had the tracking checked and all was fine, tyres are fairly good, not new by any means but not illegal either! Wondering if changing to 45 profiles may make any difference or improvement! Any advice gladly received!
Thanks
Jase
Re: Tyres on 17's
« Reply #1 on: 15 April 2013, 22:23 »
You need to stay with 205/40's to keep the gearing correct, get the tracking checked but 17's on a mk3 do tend to mean tramlining etc.
Offline barelyhuman
Re: Tyres on 17's
« Reply #2 on: 15 April 2013, 22:27 »
cheers wayne....tramlining i guess i will get used to....the aquaplaning was a proper cheek clenching moment, but to be fair there was a shed load of surface water on the roads, may look at new set of 205/40's and change the lot, see if that makes any difference. Thanks anyways mate :)
Jase
Offline tweed
Re: Tyres on 17's
« Reply #3 on: 15 April 2013, 22:31 »
What tyres you got? Why not fit a something like the toyo t1r
Offline barelyhuman
Re: Tyres on 17's
« Reply #4 on: 15 April 2013, 22:32 »
the tyres on there are a mix mash of budget tyres by the looks of it....just looking at toyo proxes now :)
Offline xionsolaris
Re: Tyres on 17's
« Reply #5 on: 15 April 2013, 23:02 »
stay away from buget tyres i have some on from when i bought the car they are always wheel spinning in the wet and feels like your driving on ice sometimes
Offline barelyhuman
Re: Tyres on 17's
« Reply #6 on: 15 April 2013, 23:05 »
defo agree there mate!
Offline berry9112
Re: Tyres on 17's
« Reply #7 on: 16 April 2013, 10:20 »
Dont mix and match! specially not with budgets. Keep atleast the front axle the same tyres both sides, front to rear is ok but not different on all four corners. I run 195/40 on 7.5 +8.5's the front can pull a bit, although the tramlining got considerably less when i cut the bumpstops down.
Dont skimp on the only thing thats connecting you to the road.
Offline barelyhuman
Re: Tyres on 17's
« Reply #8 on: 17 April 2013, 18:43 »
cheers for the advice dudes....on a mission to find some decent tyres, replace the lot and get the tracking checked (again!) and should be living the dream then! :)
Jase
Offline Len
Re: Tyres on 17's
« Reply #9 on: 17 April 2013, 21:00 »
Uniroyal rainsport 2's! Great tyres! Way better than Toyo's
www.sas.org.uk
www.the-ace.org.uk
