Author Topic: alignment after polybushing?  (Read 2805 times)
Offline blueandy
« on: 15 April 2013, 21:41 »
I have a trackday at Combe on Monday next.
I was going to polybush the front wishbones and rear axle beforehand to stiffen it up a shade.
I'm thinking now though that I should hold off as I wont be able to get the alignment checked before the day..
what do you think, will removing the back axle put the tracking out?
Offline sharki786
  • GOT BOOST??
Re: alignment after polybushing?
« Reply #1 on: 15 April 2013, 21:50 »
You cant adjust the tracking on the rear as its a solid beam/axle. Only fronts can be adjusted. Also poly bushing the fronts MAY make a slight difference to the tracking (was told by a lodge tyre worker)
*****MK3 Anniversary*****
*****MK4 GTI T*****
« Reply #2 on: 15 April 2013, 21:56 »
It is always best to get the alignment checked / adjusted after any suspension work or repairs
Offline tweed
« Reply #3 on: 15 April 2013, 21:58 »
Make time and get it checked! Take a sick day  :grin:
Offline Foreveryoungaus16v
« Reply #4 on: 16 April 2013, 12:40 »
Agreed :cool:
163 BHP (TSR POWER RUN)
VW BUSH
« Reply #5 on: 16 April 2013, 13:41 »
Wont take long to shred a set of tyres on track if your alignment is out
Offline tshirt2k
  • Been there...Done that...
« Reply #6 on: 16 April 2013, 13:51 »
There is some adjustment at the mountings. People rarely do it but toe can be changed slightly.
Mk3 ABF 16VT Megasquirt V3
Offline tweed
« Reply #7 on: 16 April 2013, 16:32 »
Could you explain how you can adjust toe please? I got toe in I would like to loose but can't see how you can.
I can understand castor.
Offline GOLF-MK3-GTI
« Reply #8 on: 16 April 2013, 16:37 »
Would like to know too, as i'm going to book my car in for full wheel reset, and the chap said the same thing as what sharki said. so if it's do-able, i would like to know  :wink:
Offline tshirt2k
« Reply #9 on: 17 April 2013, 13:24 »
You can adjust the direction the wheels face in comparison to the car on the bolts. The toe in or out of the wheels can be adjusted using those camber/toe shims if required. The toe can affect handling and tyre wear.
This link shows that it can be adjusted. On a mk2 but similar setup.
Another here
It may be the cause of alot of mk3's pulling to one side even after alignment
« Last Edit: 17 April 2013, 13:30 by tshirt2k »
