Author Topic: Exhaust  (Read 3134 times)
Offline -Craig-
Exhaust
« on: 15 April 2013, 21:12 »
Hey guys, am I right in thinking that I need a down pipe and a de-cat to mate onto my miltek cat back? Is a 3" beat?
Any recommendations? Thanks
Offline dom
  • Back in a Mk4
Re: Exhaust
« Reply #1 on: 15 April 2013, 21:32 »
Going by your other posts I'm assuming you have a 1.8t, in which case the Milltek will be 2.5" and it should come with a reducer to attach to your standard cat.
Offline -Craig-
Re: Exhaust
« Reply #2 on: 15 April 2013, 21:55 »
So I need a miltek 2.5" down pipe and decat? Thanks
Offline dom
  • Back in a Mk4
Re: Exhaust
« Reply #3 on: 15 April 2013, 22:49 »
You don't need to change the downpipe/cat in order to fit the milltek cat-back. The most restrictive part of the exhaust system is the downpipe so it wouldn't be a bad idea to change it, in which case any 2.5" system will do :afro:
Offline -Craig-
Re: Exhaust
« Reply #4 on: 16 April 2013, 13:06 »
I currently got a miltek cat back on there so if I get a 3" down pipe that will be ok?
Would I also benefit from a forge tip? If so where can I get one? Thanks  :evil:
Offline benny.banks
Re: Exhaust
« Reply #5 on: 16 April 2013, 17:09 »
forge?
Offline dom
  • Back in a Mk4
Re: Exhaust
« Reply #6 on: 16 April 2013, 17:18 »
If it is a true 3" downpipe then you will need a reducer.
If it is a 3" downpipe which actually reduces at the end (which some do) then it should be ok.
An aftermarket TIP would also be beneficial, forge are good, I have a Venair one which is excellent. Some people also run Creation Motorsports ones which can be had cheaper.
Offline -Craig-
Re: Exhaust
« Reply #7 on: 16 April 2013, 18:00 »
What is the actual pipe (tip) I need, is the turbo intake hose? Or link please :)
Offline dom
  • Back in a Mk4
Re: Exhaust
« Reply #8 on: 16 April 2013, 19:51 »
Again, you don't need it. It depends on your engine code but something like this:
http://www.ebay.co.uk/itm/VW-GOLF-MK4-1-8T-20V-SILICONE-TURBO-INTAKE-PIPE-AUM-AUQ-/160979312681?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item257b1d6029
Offline -Craig-
Re: Exhaust
« Reply #9 on: 16 April 2013, 20:58 »
My engine code is AGU? Thanks mate.
