Author Topic: Loss of power ??  (Read 2873 times)
Offline rfn_hodgson
Loss of power ??
« on: 15 April 2013, 19:45 »
Hello fellas new to the tdi scene I picke up a gt tdi 150 other week ran fine till yeaturday and I turned if f the cr to drop a mate off then as I went off again 200 meters down the road no power wouldn't budge above 2000 revs so I turned off the car hoping it to be a fault code but started up again and still the same for about 6-800 meters then suddenly all the power was back to normal and been fine since.
Now I know this happened on my dads old Peugeot 406 and it turned out to be fuel blockage/ the manual fuel pump
Can you please confirm or otherwise diagnose a possible outcome to this problem I have :)
Thanks in advance fellas
VW Golf MK4 1.8 Turbo AUQ 203 BHP-more now :) , ultimate vacuum delete, Forgre 007p-new piston, Oil catch can, s3 boost set up, FMIC, silicone TIP, full turbo back exhaust, stage 1 map, lowered on V-maxx coilovers  audi tt Quattro alloys
Offline scarr89
  • Mk4 Golf, DERV FTW!
Re: Loss of power ??
« Reply #1 on: 15 April 2013, 21:06 »
Verryyy strange  :undecided:
Do you have access to VAGCOM? If so, scan it. That will probably tell you straight away.
It could have been an extreme case of sticky VNT, sticking for a good few seconds and then re opening. Hard to say...
What is your fuel filter like, perhaps give it a change and see if you notice a change.
Offline rfn_hodgson
« Reply #2 on: 16 April 2013, 06:05 »
well i did have a code reader for my mk4 gti 1.8 turbo and it worked on that but not on this diesel then i found out that this gt tdi is an import does that make any difference??
and what is this VNT?? well im giving it a good service at the end of the month so im going change all the filters then :)
Offline scarr89
« Reply #3 on: 16 April 2013, 07:02 »
Offline rfn_hodgson
« Reply #4 on: 16 April 2013, 07:54 »
yea found out from vw that it was originally sold in germany..... when bitish soldiers are based there they get tax free cars and they then bring them over here eventually so it a uk spec import lol
Offline scarr89
« Reply #5 on: 16 April 2013, 18:13 »
Oh cool. Well I imagine the code reader will work, no reason why not. Give it a whirl.
