Author Topic: Spacers & Longer Bolts??  (Read 1591 times)
Offline mjb
  • Mk3 Addiction
« on: 15 April 2013, 16:45 »
I am looking to space my Wheels out approx 10mm at the rear and 5mm at the front - I am running BBS Solitude 15's so do I need longer bolts at the back and if so what size and where the heck do I buy em' from!!!........
Sorry for the terrible question  :whistle:
Instagram @mjbampt
Golf Mk7 Wagon (Work), Mk3 Gti 16v More Door, Mk3 Gti 8v (RIP)
Offline tweed
Re: Spacers & Longer Bolts??
« Reply #1 on: 15 April 2013, 17:08 »
10mm longer than standard. So go take one out and measure the thread then add 10mm
Offline xionsolaris
« Reply #2 on: 15 April 2013, 20:22 »
What advantages do you get spaced with spaced wheels wouldnt that create a little bit of negative camber as it will creates a bit of distance away from the hub which will angle the will a little please correct me im a wheel spacer noob
Offline tweed
« Reply #3 on: 15 April 2013, 20:50 »
Nope does not effect camber or anything. Won't effect handling or bearings at 10mm aside. Unless your et is like -20 then you've got problems with clearance.
If you want camber you need to get camber shims.
Offline xionsolaris
« Reply #4 on: 15 April 2013, 21:10 »
so its just a look then these spacers so hubcentric 30mm wont improve any handling at all
« Reply #5 on: 15 April 2013, 21:19 »
Any spacer above 5mm will need longer bolts.
Offline tweed
« Reply #6 on: 15 April 2013, 22:11 »
Nope. Low centre gravity will make a huge difference though.
