Author Topic: vcds-lite  (Read 8174 times)
Offline markgti1.8t
vcds-lite
« on: 14 April 2013, 21:09 »
can i use vcds-lite  de-immobilise a ecu
AGU fk coilovers Powerflex top mounts full 3inch decat turbo back viper induction kit fmic vr6 clutch g60 flywheel catch can 007 forge dv Power flex wishbone bushes  Power flex dog mount under brace JOM  ADJUSTABLE Drop Links Walbro 255lph INLINE Fuel Pump wmi now fitted WAITING TO FIT VR6 MAF SAAB RED TOP INJECTORS STILL TO BUY K300 TURBO  CON RODS LSD
Offline Dalo Harkin
Re: vcds-lite
« Reply #1 on: 14 April 2013, 21:31 »
Are you using a cheap eBay dongle? If so then no, most won't even delete fault codes
Offline markgti1.8t
Re: vcds-lite
« Reply #2 on: 14 April 2013, 22:15 »
i have the ebay cable working reading faults and deleting them as thinking of buying a mapped ecu so wondering if i could do it with vcds-lite
« Last Edit: 14 April 2013, 22:17 by markgti1.8t »
Offline Dalo Harkin
Re: vcds-lite
« Reply #3 on: 15 April 2013, 13:03 »
It wont be deleting them, it will be removing them from the current list not deleting them.
No mate, you need someone with proper VAGCOM
Offline topher
  • Administrator
  • fully functioning
Re: vcds-lite
« Reply #4 on: 15 April 2013, 19:24 »
you won't need to remove the immo, AGU will be immo2 so you can just code the ECU to your immobiliser but you will need full vcds for that
Offline itavaltalainen
Re: vcds-lite
« Reply #5 on: 15 April 2013, 22:50 »
are you using vcds lite a shareware or fully registered?
fully reg vcdslite should be able to do it for older pre-can cars.
Offline markgti1.8t
Re: vcds-lite
« Reply #6 on: 18 April 2013, 20:41 »
would vcds release work
