Author Topic: First scan Today  (Read 7264 times)
Offline northeast_gti-t
  • "1.8T AGU"
First scan Today
« on: 14 April 2013, 17:10 »
Got vcds lite version installed for the non genuine lead so thought it a good time to scan the mk 3 for any codes  :laugh: :lipsrsealed: heres what came up :
Airbag
1 Fault Found
00532 - supply voltage B+
            07-10 signal to low - intermittant
looked up on ross tech and i am assuming the battery has been disconnected at some point prior to me getting the car so i have just cleared this one
No engine fault codes :afro:
 :lipsrsealed:
mmmmmmmm
Chassis type - 1H Vw Golf/vento III
Scan 01.02.03.08.12.15.25.41.56
Address 01 Engine        Labels 037-906-025-ADYLBL
 Controller. 037 906 025R
 Component: SIMOS 4S               2104
 Coding    00000
 Shop# WSC  00000
 VCID: 2237698B80D7
No fault code found
Readiness N/A
Address 03 ABS Brakes        Labels 3A0-907-379 LBL
    Controller: 3A0 907 379
     Component: ABS        ITAEE   20C V00
    Coding: 03604
    Shop# WSC 00000
     VCID   E7A1B89F9675
8 Faults Found
00283 - ABS Wheel Sensor. Font Left (G47)
            35-00 - -
00283
Contents [hide]
1 00283 - ABS Wheel Speed Sensor Front Left (G47)
1.1 00283 - ABS Wheel Speed Sensor Front Left (G47): Signal Outside Specifications
1.2 00283 - ABS Wheel Speed Sensor Front Left (G47): Electrical Fault in Circuit
1.2.1 Possible Causes
1.2.2 Possible Solutions
1.3 00283 - ABS Wheel Speed Sensor Front Left (G47): Mechanical Malfunction
1.3.1 Possible Causes
1.3.2 Possible Solutions
Possible Causes
Open Circuit in Wiring from/to ABS Wheel Speed Sensor Front Left (G47)
ABS Wheel Speed Sensor Front Left (G47) faulty
Possible Solutions
Check Wiring from/to ABS Wheel Speed Sensor Front Left (G47)
Check ABS Wheel Speed Sensor Front Left (G47)
Also On there fault code 00285,00287 and 00290
Looks like replacing of all four abs sensors then  :grin:
2000 Mkiv GTi 1.8T AGU
Offline Rhyso
Re: First scan Today
« Reply #1 on: 14 April 2013, 17:14 »
Cant beat the oldies  :grin:
  • "1.8T AGU"
« Reply #2 on: 14 April 2013, 17:29 »
:grin: :lipsrsealed: Nope another job for me to add search for some sensors it is  :grin:
