Golf mk2
16V GTI idle revs
Topic: 16V GTI idle revs (Read 2062 times)
caddygti
16V GTI idle revs
14 April 2013, 11:27 »
my mk2 golf 16v gti is running at 1200 at idle.. what could this be?
xionsolaris
Here all the time
Re: 16V GTI idle revs
14 April 2013, 11:32 »
Cold or when hot
Gambit
Forum addict
14 April 2013, 18:47 »
If the idle screw is having no effect then i bet the injector seals are shot/hard
caddygti
15 April 2013, 11:45 »
It runs at bout 800 on start up but after drivin for a few mins it rises to 1200
Gambit
Forum addict
16 April 2013, 16:28 »
injector seals. with it up to temp & running spray some wd40 down into the injector seats/seals if the engine note changes then there is your cause
KRdubber
18 April 2013, 02:54 »
If you have no luck with that good point maybe the Idle Stabilisation Valve is stuck open?
caddygti
Reply #6 on:
19 April 2013, 09:22 »
it may be the injector seals because when it was cold it runs very low revs and cuts out.. are the injector seals your talking about the o-rings where the injectors enter the block?
Gambit
Forum addict
Reply #7 on:
19 April 2013, 10:48 »
yep they go hard & crispy over time
handy & cheaply fixed.
caddygti
Reply #8 on:
20 April 2013, 10:45 »
just got some ordered, cheers for the help dude
Gambit
Forum addict
Reply #9 on:
24 April 2013, 14:08 »
you'll need to reset the Co% after fitting them
Golf mk2
16V GTI idle revs
