Author Topic: Golf MK3 Door Wiring Removal  (Read 1594 times)
Offline lagrynfaya
« on: 13 April 2013, 17:56 »
Hello everyone, i am breaking a golf mk3 1.9d and i don't know how to remove the wiring of the doors i can see that there is a block connector on the frame (under the dash for the front) but i can't figure out how to remove it  :embarrassed: . Can anyone give me a bit of advice ??
Offline Len
Re: Golf MK3 Door Wiring Removal
« Reply #1 on: 13 April 2013, 18:00 »
Pull away the concetina rubber sheath from between door and frame.
Oh yeah then you will see a big retaining knob, undo that and should come apart.
www.sas.org.uk
www.the-ace.org.uk
Offline lagrynfaya
« Reply #2 on: 13 April 2013, 18:19 »
So when i do that it will free the block connector and it will come off with the door ?
« Last Edit: 13 April 2013, 18:22 by lagrynfaya »
Offline sharki786
  • GOT BOOST??
« Reply #3 on: 13 April 2013, 21:05 »
Just unscrew it from the plastic huge nut bit on the door
*****MK3 Anniversary*****
*****MK4 GTI T*****
Offline northeast_gti-t
  • "1.8T AGU"
« Reply #4 on: 13 April 2013, 23:29 »
/\ /\ /\ as said i found out this way easy to do though all the same  :wink:
2000 Mkiv GTi 1.8T AGU
