Author Topic: nut sacks!!!  (Read 1761 times)
Offline asboGTI
nut sacks!!!
« on: 13 April 2013, 12:26 »
So I put my nut optic trim in and my new knob. I am changing the gear knob cause I ain't happy with it  :embarrassed: (before anyone says once the pics re up). but that's not my only problem I kinda busted the side bits on my radio cage so my questions are:
Best place to get a new radio cage?
How long will it take to do?
How hard to change a radio cage?
vw golf mk4 ARZ 1.8T pipercross panel filter, xenon headlights, JOMS coilovers, forge 007p with green spring, audi tt anti roll bar, 3inch ebay trubo back exhaust, COOKIES MONSTER STICKER(adds bhp I swear)
Offline AD1.8T
Re: nut sacks!!!
« Reply #1 on: 13 April 2013, 12:33 »
Do you mean you snapped the clips the side trim goes on ?
Offline asboGTI
Re: nut sacks!!!
« Reply #2 on: 13 April 2013, 12:37 »
Yep that's exactly what I mean it's so frustrating
Offline AD1.8T
Re: nut sacks!!!
« Reply #3 on: 13 April 2013, 12:40 »
Couple of dabs of super glue behind enough to hold it but not too much you cant get it off and just hold them on with some masking tape untill dry .... If you buy a new one its a ball ache to change and the chances are you will do it again eventually !
Offline Nino
Re: nut sacks!!!
« Reply #4 on: 13 April 2013, 12:45 »
+1
Current - MK6 GTi Edition 35
Offline asboGTI
Re: nut sacks!!!
« Reply #5 on: 13 April 2013, 12:57 »
this is what is going on now but i am properly OCD about this so i will changing it
right heres the pics give some feedback:
Offline dom
  • Back in a Mk4
Re: nut sacks!!!
« Reply #6 on: 13 April 2013, 14:32 »
I'd be sanding it down to the aluminum underneath personally :wink:
Offline Scott D
Re: nut sacks!!!
« Reply #7 on: 13 April 2013, 15:23 »
looks decent as is
anything is better than the wooden trim  :grin:
2003 1.8T GTI 180 - APR Stage I, S2000 Filter, R-Tech Supersize TIP, Bilstein B12 Suspension, 18" OZ Superleggera, Recaro Heated Leathers, US Spec Rear Lights, N249/SAI/PCV Delete
1.8T AUQ - 241bhp & 286 ft-lb
R-Tech Map, Forge FMIC, SFS Oversized TIP, Ported Manifold, Milltek Turboback non res exhaust, Forge 007p, N249 & N112 delete, SAI delete, S2000 Air Filter, Sachs clutch & Lightweight Flywheel
Offline harlemex
Re: nut sacks!!!
« Reply #8 on: 13 April 2013, 15:39 »
what made you pick that knob??  :sick:
Offline asboGTI
Re: nut sacks!!!
« Reply #9 on: 13 April 2013, 15:46 »
thought it tied in with the net optic trim dw the knob is gonna get changed and i didnt wanna do brushed ali as its too common
