Author Topic: Heat - what else could it be?  (Read 1038 times)
Offline Dalo Harkin
« on: 13 April 2013, 12:20 »
Hi guys,
Right coincidence or not since having my stage 2 done, the inside of my car gets very warm, just been driving it now and I would say its the equivalent of having the heaters on.
Now it had a new VW genuine temp sensor a few months back and a thermostat probably around 6m ago, I know I have a very small leak down the side of the timing chain cover :undecided: (its that small a leak, I have had to top it up around once a month) Cam belt is due in around 1yr from memory
The temp gauge sits at 90 after warming up and it doesn't drop when you go faster so am I right in thinking this rules the thermostat out as a possible cause?
Struggling here to find what it could be.
Offline Chris#101
Re: Heat - what else could it be?
« Reply #1 on: 13 April 2013, 12:36 »
Have you got econ?
Put the temperature as low as it goes then turn off econ using the fan speed?
Has this now lowered the cab temperature?
          2003 1.8T: R-tech Live Cutom Stage 2 remap: N249 Bypass : Forge T.I.P : Forge 007p  : Forge Actuator, yellow spring : Toyosports F.M.I.C : Toyosports C.A.I :        PCV simplified - oil catch can : 42' Draft 3" turbo back non res exhaust system : Devils own W.M.I : 231bhp & 258lbs-ft
Offline AD1.8T
« Reply #2 on: 13 April 2013, 12:44 »
Even when the heaters are switched off they still dribble out abit of air so whatever temp you have it set to will still come through enough to change cabin temps ....eventually
Offline dom
  • Back in a Mk4
« Reply #3 on: 13 April 2013, 14:33 »
You still got all your heat shields on?
Offline harlemex
« Reply #4 on: 13 April 2013, 15:32 »
You should get a thermometer in the cab and jot down some readings, that way we could do some comparisons.
Offline Dalo Harkin
« Reply #5 on: 14 April 2013, 09:18 »
Have you got econ?
Will give that a go
Offline Dalo Harkin
« Reply #6 on: 14 April 2013, 09:19 »
Yes all still on, and I have even added the K04 ones on, that sit above the manifold
Offline Dalo Harkin
« Reply #7 on: 14 April 2013, 17:57 »
Have you got econ?
Did as suggested and now its fine, so cheers Chris  :wink:
Weird though as I would have thought off was off and not the unit off but the heat the same  :undecided:
« Last Edit: 14 April 2013, 18:07 by Dalo Harkin »
