Author Topic: Forge 007 Recirc Valve.  (Read 1584 times)
Offline markymarkg
« on: 13 April 2013, 11:14 »
Just treated my 1.8T AUM to a Forge recirc valve....
Just to add that the car is standard(so i have been told) apart from a BMC carbon intake. You can really feel the pressure of the turbo winding up and the surge of power(like a power band) from the turbo and it sounds great, a slight whistle from the turbo spinning up, then when off the throttle, you can hear what i think is the wastegate chirp and the boost pressure being dumped....its sound pretty good!.
But....I've fitted the Forge recirc and all that is gone!. No surge of power, only a very slight whistle from the turbo and no noise at all when you let off the gas, the car even feels slower!!
Anyone??   :whistle:
P.s. It had the standard plastic DV before i fitted this.
Offline dom
  • Back in a Mk4
Re: Forge 007 Recirc Valve.
« Reply #1 on: 13 April 2013, 11:22 »
To be honest, unless you're mapped or the standard dv was leaking I wouldn't have bothered changing it.
What colour spring did you fit? Should be green if your car is standard, yellow if mapped.
Offline markymarkg
« Reply #2 on: 13 April 2013, 11:26 »
Green is fitted....Never listen to a mate then!!
Offline dom
  • Back in a Mk4
« Reply #3 on: 13 April 2013, 11:35 »
Don't get me wrong, it won't do any harm, I just don't see the benefit unless you're planning on having it mapped soon.
Offline markymarkg
« Reply #4 on: 13 April 2013, 11:46 »
Thanks for the info...
Got a stanless exhaust to put on but no plans for a re-map yet........!
Gonna put the plastic one back on i think.
Offline dom
  • Back in a Mk4
« Reply #5 on: 13 April 2013, 12:06 »
I'd stick with the forge one now that you have it, then get yourself booked in at R-tech :wink:
Offline Dalo Harkin
« Reply #6 on: 13 April 2013, 12:24 »
I would put money on the old one being cracked/leaking boost
Offline markymarkg
« Reply #7 on: 13 April 2013, 12:43 »
well, defiatly not cracked and if it was the leaking to atmosphere you wouldn't hear a thing over the engine.
It'll be as Dom69 said.......How much is a remap at R-Tech.
Offline mar_k
« Reply #8 on: 13 April 2013, 16:44 »
Did you buy the Forge007p new or used?
What piston is fitted to the Forge 007p?
If its the old style piston, there's a good chance its leaking boost.
I had the same issue, I have now rebuilt the 007p using the new design piston with the 'O' ring fitted to the bottom of it.
Offline brewey
« Reply #9 on: 13 April 2013, 17:12 »
Upwards of £200 depending on what stage etc you want. It's all listed on their website.
2000 1.8T ARZ - OEM+
