Author Topic: DV reversed?  (Read 2415 times)
Offline GTi_James
DV reversed?
« on: 12 April 2013, 23:27 »
Hey guys,
Quick question, what are the advantages or disadvantages of reversing the DV? Read a post on vortex supplied buy a fellow forum member but it doesn't state a end result so there's a lot of smoke but no fire.
Can anyone help us?
Thanks!
Offline beppe2672
Re: DV reversed?
« Reply #1 on: 12 April 2013, 23:44 »
I believe you get a little bit more noise when it's reversed. But the probelem is you run the risk of boost pressure pushing the valve off its seat and prematurely venting precious boost!
1999 1.8t AGU, KNN Panel filter, Smoothed air box, Custom CAI, Forge 007 dv, REVO stage 1, 3" eBay TBE. Audi TT quickrack.
To come - A DIY hybrid K03 and a whole lot of supporting mods!
Offline crazy golf
Re: DV reversed?
« Reply #2 on: 12 April 2013, 23:52 »
if its a piston type like forge then revered is the way its ment to be (boost pushing against bottom of the piston)
Offline GTi_James
Re: DV reversed?
« Reply #3 on: 13 April 2013, 07:18 »
yeh i was thinking of only doing it with a forged DV, cheers fellas
Offline Dalo Harkin
Re: DV reversed?
« Reply #4 on: 13 April 2013, 11:16 »
I asked this a while ago and some people were under the impression it can be bad for the car.
I had mine reversed and it made a really horrible chirp noise........ so put it with the vac pipe inlet facing up (normal way)
Offline Nino
Re: DV reversed?
« Reply #5 on: 13 April 2013, 12:11 »
Ive been wondering this myself i plan on reversing my forge 007p an see if it makes any diff
Current - MK6 GTi Edition 35
Offline Chris.
Re: DV reversed?
« Reply #6 on: 13 April 2013, 12:25 »
Whoever told you that didnt know what they were talking about.
Boost always goes into the side of the piston.
AS stated above, you have 20psi of pressure im most cases pushing the piston up off its sealing surface  which causes that valve to leak.
Click For Build Thread
Offline Prawny
  • R-tech power!!!
Re: DV reversed?
« Reply #7 on: 13 April 2013, 12:37 »
Incorrect.
As Chris and Beppe have stated, charge pressure should be on the side of the piston. This is part of the design that allows a fast acting DV with low spring pressure that will not leak.
By reversing it and allowing boost to act on the bottom of the piston, you're making it as crap as every other piston type BOV that needs high spring tension to remain closed, which in turn leads to it not opening under light load and compressor stall, eventually resulting in turbo damage. If you don't up the spring tension, then it's likely to bleed off boost, so you lose either way.
In theory, the pressure acting on each side of the valve SHOULD be equal and opposite, so it would remain closed, but due to pressure drops across the intercooler core and then again across the throttle body,  the pressure at the charge pipe take off will always be higher than the pressure in the inlet which acts to hold the valve closed, hence it leaks.
Offline Nino
Re: DV reversed?
« Reply #8 on: 13 April 2013, 12:51 »
Interestibg read there mate. So your basically saying it installing a forge 007p in the reversed order is a big no no as it will weaken the seal and the spring which in turn will cause danage to the turbo?
Offline davemk4
Re: DV reversed?
« Reply #9 on: 13 April 2013, 14:12 »
I did loads of looking into this there loads of info on tgis. End result dont do it. It fits that way for a reason. Plus it sounds gay the other way round
2001 mk4 GTI 1.8t AUM. k&n induction kit with customer heat shield, 3'' TIP, Forge 007P, Stage 1 map, N249 bypass, 3'' downpipe and decat, 2.75'' Jetex cat back non res, Koni shockers and H&R springs 35mm, dimpled and grooved disks front and back
