Author Topic: Golf Mk3 AAZ engine question  (Read 1952 times)
Offline WeekendMechanic
  • Golf MK3 GTD
« on: 12 April 2013, 17:50 »
I bought my Golf with an induction kit installed I don`t want it there anymore and I want to put an original air box in.
But like i said I bought it with an induction filter so I don`t know what it had originally,there an empty electrical plug were the original air box used to be which I think its for the air box?Anything else I have to connect up to be properly installed like original, what do I have to buy?
Thanks.
Offline xionsolaris
Re: Golf Mk3 AAZ engine question
« Reply #1 on: 13 April 2013, 08:46 »
buy the air box for it and you will see were it lines up have a look at a pic gives you a idea were it goes http://images.forum-auto.com/mesimages/150578/AAZ.jpg
  • Golf MK3 GTD
« Reply #2 on: 13 April 2013, 11:59 »
Yes I knoww I wwould have to buy an air box butt does it have a sensor attached to it and do the pipes on the air box attach to anything else?
Offline xionsolaris
« Reply #3 on: 13 April 2013, 12:18 »
Tht induction kit was it a chep universal one my guess tht sensor thts missing is air intake temp sensor as u cant fit it on a cheap induction kit my k n induction kit has a hole to put it in on the filter the cold air feed pipe should come with a airbox sensor ill doubt youll get one with a airbox best goto scrappie as the sensor is removable quick question this wire how many pins is it is it a 2 pin
  • Golf MK3 GTD
« Reply #4 on: 13 April 2013, 12:52 »
2 pin why?,so the pipes that come with the airbox don`t connect to anything else right,and how does it attach to the car does it need clips?
« Last Edit: 13 April 2013, 13:01 by WeekendMechanic »
Offline xionsolaris
« Reply #5 on: 13 April 2013, 13:03 »
I just needed to confirm wht sensor it was 2 pin is air temp sensor try find a scrappie most of the time u have to remove the parts yourself so u can get all the bits u need if its there or go on ebay and have a look on there ask sellers if the sensor is attatched
  • Golf MK3 GTD
« Reply #6 on: 13 April 2013, 13:07 »
ok cheers :smiley:
