Author Topic: Fob Boot Unlocking  (Read 1777 times)
Offline Big_Dave
Fob Boot Unlocking
« on: 12 April 2013, 17:37 »
I'm not sure whether this is just a quirk of the car or whether something's wrong, I'm tempted to go with the latter.
Got home today, locked the car and took a load of shopping in. Came back out, pressed the boot only unlock button on the fob, boot popped up, took out shopping, closed boot. The catch made the noise it always has (like it's locking).
Then, I'm not sure why, but I checked it was locked, pushedthe VW badge in and to my surprise the boot opened and the alarm went off  :rolleyes:
So I tried again, unlocked the car, re-locked, then opened the boot with the boot only button. Closed, catch noise, then I walked around the car checking all the doors, waited one minute, tried to open the boot, same thing. It opened and the alarm went off.
I think it's probably not supposed to do that, it should stay locked like every other car I've had with this feature. Can someone confirm before it goes back to be sorted? I dread to think how many times I've left the boot unlocked in car parks becuase of this!  :undecided:
Carbon Grey Edition 35, DSG, ACC, Cruise Control, Luxury Pack, RCD 510, TPMS
Offline dubber36
Re: Fob Boot Unlocking
« Reply #1 on: 12 April 2013, 18:18 »
You are quite right. Pressing the boot unlock button should unlock just the boot and disarm the alarm, then closing the boot should automatically re-lock the boot and arm the alarm.
Does your boot lock when you lock the car in the normal way?
Offline AndyG
« Reply #2 on: 12 April 2013, 18:24 »
Big Dave,just been out to check mine.I think you have a fault,mine locks again after opening the tailgate using the boot button.
Golf 7R,DSG,5 door White,leather,rear camera.
Offline Big_Dave
« Reply #3 on: 12 April 2013, 18:53 »
Thanks for checking guys.
It does lock fine when I press the 'lock' button. Something going wrong when it's closing by the sounds of it. Funnily enough the last couple of weeks I've had an annoying rattle from the back somewhere, may well be related.
Will report back next week. Cheers!  :cool:
Offline Big_Dave
« Reply #4 on: 20 April 2013, 08:57 »
So this is a bit embarrassing...the dealer, after investigating themselves for an hour found that this is a quirk of later MK.6's. the reson is that if you shut your boot and have dropped your keys in you have chance to retrieve them. Apparently it locks after approximately 1 minute...and even says it in my book  :rolleyes:
Oops. The dealer did investigate another issue that was rectified though. However, in doing so they've scratched my pristine alloy  :angry: thankfully they've agreed a repair...the repair better be unnoticeable.
Offline Booth11
« Reply #5 on: 20 April 2013, 19:01 »
Yeah, mine does the same as yours and is a 62 plate.  As you say, it's in the manual  :wink:
2012 MK6 GTI DSG
2008 MK5 GTI DSG
2005 MK5 GTI Manual
