Author Topic: No speedo and constant refuel buzzer  (Read 791 times)
Offline mar_k
« on: 11 April 2013, 18:06 »
My mates Golf 1.8t has developed a problem with the speedo,
It doesn't work, The car hesitates and stutters on boost, Scanned with vcds and got
16885 vehicle speed sensor implausible signal
Along with this the petrol 'please refuel' beep keeps going off when pulling away and the petrol
gauge goes down.
Need help with this one, Are they connected or are they 2 different faults?
Offline Dalo Harkin
Re: No speedo and constant refuel buzzer
« Reply #1 on: 11 April 2013, 19:52 »
Did both faults happen at the same time?
Speed sensor is easy to replace, but the fuel issue seems a big problem, unless the float sensor is jammed against the inside somewhere
Offline mar_k
« Reply #2 on: 11 April 2013, 20:03 »
Both happend at the same time, Incidently I have found a thread on Vortex about this very thing,
Seems its a wire that is most likely broken in the trunking below the battery tray.
I will be investigating the theory and report back tomorrow.
