Author Topic: Turbo Whistle  (Read 4906 times)
Offline sammerry
Turbo Whistle
« on: 11 April 2013, 14:15 »
I have a question,
Recently I have noticed my turbo whistle has gotten louder in my MK5 GTi in the last week, could this be because I have recently started using v-power rather than standard pump fuel or could it be something more serious?
My car has just hit 70000miles.
Offline Poached
Re: Turbo Whistle
« Reply #1 on: 11 April 2013, 20:48 »
I have a question,
Possibly a torn diaphragm on the Diverter valve. It's Bolted onto the turbo so not the easiest item to get to and it's held in place by 3 bolts.
http://www.mk5golfgti.co.uk/forum/index.php?topic=44709.0
Do you know if it's been checked at all?
« Last Edit: 11 April 2013, 20:59 by Poached »
Offline sammerry
Re: Turbo Whistle
« Reply #2 on: 12 April 2013, 08:49 »
Thanks for the reply,
It could be this, I thought it was performing ok but driving to work this morning it seem to be losing a little boost at higher rpm's....
I will investigate....
Sam
Offline Poached
Re: Turbo Whistle
« Reply #3 on: 12 April 2013, 11:16 »
Sam
Yes you will lose some performance as you're leaking boost. Have it checked out, I wouldn't expect more than 1 hours labour to rectify the fault.
« Last Edit: 12 April 2013, 17:33 by Poached »
Offline sammerry
Re: Turbo Whistle
« Reply #4 on: 12 April 2013, 13:43 »
Going to get and obd plugged in to make sure, then get my bro to do it, its damn useful have a mechanic in the family! I would do it myself but I dont have ramps.....
Offline AlanD
  • MK5 2.0T 16v
Re: Turbo Whistle
« Reply #5 on: 12 April 2013, 14:17 »
Mine is currently in this state. Its got a leak somewhere which is very audible as you go up the rev range. The leak can be from any number of places, I just haven't got around to sorting out.
Shouldn't do any damage to the car but you will lose performance so better off getting it looked at sooner rather than later. A simple check you can do is the check all your hoses and corresponding jubilee clips to make sure they are all on tight.
Offline sammerry
Re: Turbo Whistle
« Reply #6 on: 22 April 2013, 13:49 »
Turns out it was the DV, great big split in the diaphram, possibly one of the easiest fixes ever, took all of 15 mins.....
thanks for the help guys! :smiley:
