Author Topic: Breather Pipes & Throttle Body Clean  (Read 3302 times)
Offline GOLF-MK3-GTI
« on: 11 April 2013, 10:14 »
Sat in traffic today and noticed the rev needle fluctuate and acting very lazy.
The other day i notcied the camcover had fresh oil marks on it. after it been on the motorway, since i'm replacing the breather pipes.
Shall i clean the throttle body out too, if so do i need to re-align it? ITS AN 8v gti AGG.
also shall i clean the maf sensor, with air sensor clean?  :tongue:
Offline Khare
  • The bear that khares
Re: Breather Pipes & Throttle Body Clean
« Reply #1 on: 11 April 2013, 12:37 »
Yes clean the throttle body, no need to realign, that's for Mk4's onwards as far as I know. I've never had to realign mine and never had any trouble when removing it, which has been many many times.
Offline boneybradley
  • Back in a Mk3...
« Reply #2 on: 11 April 2013, 13:03 »
I would advise using a new t.b gasket (only a couple of ££ from vw)
Offline madsb
« Reply #3 on: 11 April 2013, 13:46 »
Clean the TB but don't expect any wonders :) might as well be the MAF sensor, so clean that too.
You can disconnect and reconnect the battery if you want to realign without using vagcom (if you don't have it, otherwise definitely use vagcom). reconnect battery and turn ignition, but don't start the engine. Don't touch the gas pedal or anything for 30 seconds or so (you should be able to hear it realigning). done.
Offline madsb
« Reply #4 on: 11 April 2013, 13:48 »
oh, and also might be worth spraying some carb cleaner or tb cleaner into both ends of the breather hose.
Offline DCmk3
« Reply #5 on: 11 April 2013, 15:44 »
I've always realigned mine when I unplug the TB, even if I don't remove it, but that's really personal preference since I have the software readily available.
2014 Mk7 GTI - Littco L500
« Reply #6 on: 11 April 2013, 15:57 »
Is yours 2E or AGG?
I've read only 2E need aligning, AGG don't.
  • Back in a Mk3...
« Reply #7 on: 11 April 2013, 16:00 »
B.t.w if cleaning the thottle body only use proper electrical cleaner (isopropol alcohol stuff?)
oh and I have never realigned the t/b (ady or agg models.. Maybe you need to on a 2e?)
Offline DCmk3
« Reply #8 on: 11 April 2013, 16:06 »
Is yours 2E or AGG?
Mine is neither, it's only a little 1.8 8v..  :whistle:
« Reply #9 on: 11 April 2013, 19:26 »
There's only one way to find out. Clean the damn thing  :grin:
