Author Topic: for anyone wanting to do the R32 thang :)  (Read 7050 times)
Offline GTi_James
« on: 10 April 2013, 13:43 »
found this and few more bits
helped me out a bit, have a butchers and correct anything that may be amiss  :wink:
MK4 R32 Part Numbers - Please double check to confirm
Some parts are listed for LHD, so please double check before ordering:
Aero Wiper Blades:
Driver Side: 1J1 955 425 A
Passenger Side: 1J1 955 426 A
Blade Inserts: 1J0 955 429 A
Air Box Filter:
1J0 129 620
Amp/Changer Trunk Trim:
1J6 867 427 AE 8JS
Aristo Wheels:
1J0 601 025 BA 88Z
Armrest:
Black Leather Lid: 3B0 867 173 KWL
Black Armrest Body: 3B0 867 174 A94
Left Armrest Trim: 1J0 864 279 A 2QL
Right Armrest Trim: 1J0 864 280 A 2QL
Mounting Kit: 1J0 898 079
Optional cup holder: ZVW 919 001
Aspherical Mirror Glass:
Left: 1J1 857 521C
Right: 1J2 857 522C
Badges & Nameplates:
Chrome Rear VW logo: 1J6 853 630 B FCS
Chrome Front VW logo: 1J0 853 601 FDY
Black Rear VW logo: 1J6 853 630 A 041
Black Front VW logo: 1J0 853 601 A 041
R32 rear nameplate: 1J0 853 675 Q 739
R32 front nameplate: 1J6 853 679 D PWV
Battery:
Battery Cover: 1J0 915 435 C
Belly Pan/Dampener:
Centre: 1J0 825 237 P
Left vertical for attachment to frame rail: 1J0 825 245 L
Right vertical for attachment to frame rail: 1J0 825 250 K (V-belt cover)
Bottom Bumper Left: 1J0 825 703
Bottom Bumper Right: 1J0 825 704
Bottom Bumper Center: 1J0 825 001
Right front fender liner 1JO 809 962 F
Left front fender liner 1JO 809 961 E
Bonnet Parts:
Clips that hold sound proof material on: 1H5 863 849 A 01C
Bora Illuminated Vents (Black):
Drivers Side Vent: 1J2 819 704 D 2AQ
Driver Side Vent Frame: 1J2 819 186 A
Centre Vents: 1J0 819 728 D 2AQ
Centre Vents Frame: 1J2 819 197 A
Passenger Vent: 1J2 819 703 D 2AQ
Brake Callipers:
Front Left: 1J0 615 123 E
Front Right: 1J0 615 124 E
Rear Left: 1J0 615 423 F
Rear Right: 1J0 615 424 G
Brake Light Switch:
1C0 945 511 A NAR (RECALL)
Brushed Aluminium Interior Trim Pieces:
Ashtray Cover: 1J1 857 351 B 4J4
Cupholder: 1J0 858 501 D 4J4 (US piece does not have cup logo)
Left vertical trim: 1J0 853 189 A 4J4
Right vertical trim: 1J0 853 190 A B41
Climatronic surround: 1J0 907 047 P 4J4
Climatronic surround (alternate, black): 1J0 907 047 M01 C
Passenger Side Pull Handle: 1J0 867 172 C NPX
Passenger Side Door Handle: 3B1 837 114 T 4J4
Driver Side Pull handle/switch housing: 1J3 867 171 A NPX
Driver Side Door handle: 3B1 837 113 L 4J4
Bumpers:
US Front Bumper Cover: 1J0 807 217 K GRU
Euro Front Bumper Cover: 1J0 807 217 H GRU
US Rear Bumper Cover: 1J6 807 421 L GRU
Euro Rear Bumper Cover: 1J6 807 421 J GRU
Bumper Torx Screw:
N 907 750 01
Bumper Speed Nut:
N 015 439 1
Cabin (Pollen) Filter:
1J0 819 644
CD Changer Mounting:
Brackets, need 2: 1J0 035 234 A
Screws, need 6: 000 051 750
Center Console:
Front: 1J1 863 201 E 2QL
Tray behind coin slot:
Insert: 1J0 858 373 C 2QL
Pad: 1J0 863 328 C B41
Center Console/Handbrake Screw Covers:
1J0 863 276 B 2QL
Cluster (OE UK - 180 MPH) with full MFA/FIS:
1J0 920 946 FX
Cluster (OE EU - 300 Km/h) with full MFA/FIS:
1J0 920 846 FX - 6 speed manual
1J0 920 846 GX - DSG
Cluster Harness Locking Connectors:
1J0 972 977 C - Green, right side.
1J0 972 977 D - Blue, left side.
Control Arms:
Left Front: 8N0 407 151 D
Right Front: 8N0 407 152 D
Cooling Fans:
290 mm - 1J0 959 455 R
345 mm - 1J0 959 455 S
Dashboard (does not include cluster):
1J1 857 002 E 84L
Dead Pedal Base Clip:
1J1 864 777A B41
Door Cards, Front LHD:
Black w/ black leather:
Left: 1J3 867 011 ED LKU
Right: 1J3 867 012 EN LKU
Flannel grey w/ grey leather:
Left: 1J3 867 011 EF LKX
Right: 1J3 867 012 EQ LKX
Black & light beige w/ beige leather:
Left: 1J3 867 011 EF LKY
Right: 1J3 867 012 EQ LKY
Door Cards, Front, RHD
Left: 1J3 867 011 EG LKU
Right: 1J3 867 012 ER LKU
Distance Pieces:
These are the fender extensions that mate the fender liner to the R bumper
Left: 1J0 806 569
Right: 1J0 806 570
Door Delocking Kit:
Metal Housing: 1K4 839 167
Cap: 3B4 839 879 A GRU
DSG Paddles (R32 OEM):
Left: 1J0 951 527 4J4
Right: 1J0 951 528 4J4
Endlinks:
Front Left: 1J0 411 315 D
Front Right: 1J0 411 316 D
Rear (same for both sides): 1J0 505 466 B
Engine Coolant:
G 012 A8 FA4
Engine Cover:
022 103 925 AD
Engine Cover (center strip):
022 103 935 AB
Engine Cover Emblem (Blue & White version):
038 103 940 F
Exhaust Flapper Solenoid:
1J0 906 283 C
Final Drive:
02D 525 010 AE
Front Upper Grille:
Primered Grille: 1J0 853 653 C GRU
Grille Backing/Frame: 1J0 853 655 G 01C
Chrome VW Logo: 1J0 853 601 FDY
Front Lower Grilles:
Centre: 1J0 853 677 F B41
Left: 1J0 853 665 D B41
Right: 1J0 853 666 J B41
Clips for centre grille: N 104 910 01
Fuel Door, Primered:
1J6 809 857 E GRU
Fuel Filter:
1J0 201 511 A
Green Top Coolant Sensor:
Sensor: 059 919 501 A
O Ring: N 903 168 02
Retaining Clip: 032 121 142
Haldex Crush Gasket:
02D 525 589
Haldex Servicing:
Fluid: G05 217 5A1
Filter: 02D 525 558 A
Wrench: T 100 66
Headlight Mount Repair Kits:
Left: 1J0 998 225
Right: 1J0 998 226
Headlight Rear Covers:
Low Beam Left: 1J1 941 607 F
Low Beam Right: 1J1 941 608 F
High Beam (Both Sides): 1J0 941 607 C
Heat Shield Fasteners:
N 019 538 2
Headlight Switch
6R Polo Brushed Aluminium Headlight Switch
Rear foglight only: 6R0 941 531 F APV
Front and Rear foglights: 6R0 941 531 G APV
Hub Caps:
OEM VW black/chrome: 1J0 601 171 BXF
Ignition Coil:
022 905 715
Interior Trim Panel Clip:
3B0 868 243
License Plate Front Mounts:
European Mount: 1J0 807 287 A
US Mount: 1J0 807 287 D B41
Mirror Motors (For Power Folding):
Window Motor LHD, Driver Side: 1C0 959 801B 017
Window Motor LHD, Passenger Side: 1C0 959 802C 017
Mirror Switch:
1J1 959 565 E 01C - Satin black, includes push spot for folding.
NGK Iridium Plugs:
101905606A
Oil Filter:
071115562
Oil Filter Housing Cover:
071 115 433
Oil Filter Housing Drain Plug:
071 115 434
Oil Pan:
021103601L
Oil Pan Drain Plug (w/ Washer):
N 908 132 01
Oil Pan Sealer:
D 176 404 A2
Oxygen Sensors (Lambda Probe):
Pre-cat, left: 022 906 262 R (Superseded by 079 906 262 F)
Pre-cat, right: 022 906 262 BB
Post-cat, left: 022 906 262 L
Post-cat, right: 022 906 262 K
Parktronic Senders:
1K0 054 630 A
Passat W8 Interior Light:
Non Sunroof Grey: 3B7 947 105 F 2EN
Non Sunroof Beige: 3B7 947 105 F 92Y
Sunroof Version Grey: 3B7 947 106 A 3EN
Sunroof Version Beige: 3B7 947 106 A 92Y
Late Sunroof Version Grey: 3B7 947 106 B 3EN
Late Sunroof Version Beige: 3B7 947 106 B 92Y
(You can tell if you have the old or new version sunroof model, by checking if your dial is spring loaded. With the sunroof FULLY open, if the dial "springs" back.... you have the late version)
6pin Connector: 3B0 972 706
3pin Connector: 893 971 993
(You can buy a pre-made loom on ebay if you desire)
Phaeton Brake Cooling Kit:
Left Cooling Duct: 3D0 615 447D
Right Cooling Duct: 3D0 615 448D
Left Splash Shield: 3D0 615 311C
Right Splash Shield: 3D0 615 312C
Radio Pockets, Single DIN:
Upper Pocket: 1J0 857 058B 1QA
Lower Pocket: 3B0 857 058 2AQ
R36 Blue Coil Pack Covers
R36 blue tubing - N 107 325 02 (Comes as 5m IIRC)
R36 blue caps (You need to get x3 of these) - 03H 971 921
R36 blue caps (and x3 of these) - 03H 971 921A
Rain Tray/Deflector:
1J1 819 415 B B41
Rain Tray Rubber Seal:
1J0 823 723
Rear Aero Wiper (from MkV platform):
Arm: 6Q6 955 707 C
Blade: 6Q6 955 425 A
Cap: 6Q6 955 435 B
Rear Ashtray Assembly & Cover:
Black: 1J0 857 962 H 2QL
Flannel Grey: 1J0 857 962 H 3SG
Light Beige: 1J0 857 962 H 4TE
Rear Ashtray Cover Caps
Black: 1J0 863 359 E 2QL
Flannel Grey: 1J0 863 359 E 3SG
Light Beige: 1J0 863 359 E 4TE
Rear Hatch (generic MkIV):
1J6 827 025 G
Rear Headrests (black leather):
Leather cover: 1J0 885 921 AT LGL
Foam padding: 1J0 885 931 B
Frame w/ attachment posts: 1J0 885 914 B
Rear Swaybar Clamp:
8A0-511-439
Rear Wiper Blade (OEM US):
1J6 955 427
Repair Wire:
000 979 133
Roof Interior Rear Molding (black):
1J6 867 617 B 54A
Rear Hatch Panels:
Bottom: 1J6 863 459 E B41
Glass Trim: 1J6 867 603 F B41
Trunk Lid Trim: 1J6 867 601 F B41
R-Line Items:
Accessory Pack: ZVW 355 018
Center Caps: JNV 601 171 BXF
Monster Mats (Front Only): ZVW 179 002 R
Seats:
Leather, Front:
Right top: 1J0 881 806 LT LGL
Left top: 1J0 882 805 GM LGL
Right bottom: 1J0 881 406 G LGL
Left bottom: 1J0 881 405 FD LGL
Leather, Rear:
Top left: 1J0 885 805 PN LGL
Top right: 1J0 886 806 N LGL -> 1J0 886 806 B LGL
Bottom left: 1J0 885 405 DN LGL
Bottom right: 1J0 885 406 DC LGL
Cloth, Front:
Right top: 1J0 881 806 LS QZZ
Left top: 1J0 882 805 GL QZZ
Right bottom: 1J0 881 406 D QZZ
Left bottom: 1J0 881 405 ET QZZ
Cloth, Rear:
Top left: 1J0 885 805 QE QZZ
Top right: 1J0 886 806 A QZZ
Bottom left: 1J0 885 405 EF QZZ
Bottom right: 1J0 885 406 DP QZZ
Sidemarker/Fender Repeater Bulbs:
N 017 752 2
Sideskirts:
Left: 1J0 853 859 B GRU
Right: 1J0 853 860 B GRU
Spark Plugs:
101 905 606 A
Splitter:
Seat Leon Cupra R Splitter: 1ML 805 903
Steering Rack:
1J1 422 063 F
Subframe Bolts:
N-907-528-01 (need 2)
N-907-349-01 (need 2)
Sunglasses Holder:
1J0 857 465 Y20 (Beige)
Sunroof Crank:
4B0 875 699
Sunvisors:
Right: 3B0 857 552 AK 3H8
Left: 3B0 857 551 AK 3H8
Bracket: 3B0 857 561 B B41
Bracket cap: 3B0 857 563 B41
Suspension Nuts & Bolts:
Front:
Sway Bar End Link (need 2): N 015 081 4
Knuckle Bolt (need 2): N 102 078 03
Knuckle Nut (need 2): N 101 064 02
Rear:
Control Arm Bolts: N 104 162 01
Control Arm Nuts: N 101 064 02
Lower Shock Bolt (need 2): N 104 281 01
Upper Shock Bolt (need 2): N 907 813 01
Tail lights (US spec):
Left: 1J6 945 095 AC
Right: 1J6 945 096 AC
Throttle Body:
022 133 062 AA
TMC Box (For use with Euro Cluster & OE navi):
3B0 919 894A
TT Spare:
Wheel: 1J0 601 027 M03 C
Tire (125/70/18): 1J0 601 324 RCO
Valve Stem Caps:
VW Blue: ZVW 355 005 B
Wheel Hub:
8N0 407 613 C
Wheel Bearing (Kit):
8L0 498 625 A
Wheel Liners:
Left: 1JM 809 957
Right: 1JM 809 958
Wheel Liner & Fender Spacer:
1J0 810 949
Windshields/Windscreens:
Front: 1J0 845 011 AD (does not include rain sensor)
Rear: 1J6 845 051 F
Windows:
Door, left: 1J3 845 201 H
Door, right: 1J3 845 202 H
Side, left: 1J6 845 041 D
Side, right: 1J6 845 042 D
Offline Nino
Re: for anyone wanting to do the R32 thang :)
« Reply #1 on: 10 April 2013, 14:09 »
Wow someone has been busy boy lol
Current - MK6 GTi Edition 35
Offline GTi_James
« Reply #2 on: 10 April 2013, 14:16 »
i try lol
Offline brett
« Reply #3 on: 10 April 2013, 14:35 »
Good effort mate lol
I only want the wheels ,eventually  :smiley:
Offline asboGTI
« Reply #4 on: 10 April 2013, 14:53 »
this has got to be book marked
vw golf mk4 ARZ 1.8T pipercross panel filter, xenon headlights, JOMS coilovers, forge 007p with green spring, audi tt anti roll bar, 3inch ebay trubo back exhaust, COOKIES MONSTER STICKER(adds bhp I swear)
Offline AD1.8T
« Reply #5 on: 10 April 2013, 15:08 »
Good effort mate although out of all that its missing the one f?!king thing i need lol
Dont suppose you know the part numbers for the grey/alcantara seat covers at all ?
Offline GTi_James
« Reply #6 on: 10 April 2013, 15:22 »
...bo-lacks, well i gotta give VW a call tomorrow and i'll let you know then mate
Offline navmk4gti
« Reply #7 on: 10 April 2013, 16:13 »
Need some more part number threads like this... i just can never be arsed make one tho :whistle:
Good job bud :wink:
Offline Rhyso
« Reply #8 on: 10 April 2013, 22:06 »
You missed the steering wheel and Xenons  :whistle:
Offline GTi_James
« Reply #9 on: 10 April 2013, 23:23 »
picky feck!
