Author Topic: changing car battery  (Read 1155 times)
Offline bullzeye
« on: 10 April 2013, 12:38 »
my battery is nackered, ive just been and got a replacement but i see theres like a pack of wires on the top of the old battery,
now do i need to know anything before removing it? will i loose any codes or anything? thankyou
cheapest mobile provider arround order a free sim with £5 credit www.giffgaff.com/orders/affiliate/s3cr3t
Offline GTi_James
Re: changing car battery
« Reply #1 on: 10 April 2013, 12:42 »
when you disconnect your battery you'll have to reset anything non standard to the car, shouldnt throw up any new codes but advise clearing any codes currently stored, change batts over and reread. the wires on top are part of the fusebox, this should be removed quite easily, couple of bolts, dont forget to remove the negative first and keep it away from body work and metal  :whistle:
Offline bullzeye
« Reply #2 on: 10 April 2013, 12:47 »
my car is standard. i was worried about radio codes (original radio), Immobiliser and stuff like that, i have got a code reader to delete any engine codes.
Thanks
Offline GTi_James
« Reply #3 on: 10 April 2013, 13:04 »
ive unplugged mine with no issues with that tbf
Offline barrym381
« Reply #4 on: 10 April 2013, 13:13 »
Thanks
your radio code is stored on ecu to so wont lose that  :smiley:
Offline Steve_PD
« Reply #5 on: 10 April 2013, 13:29 »
Thanks
No problems with any of that, crack on :wink:
