Author Topic: Canon 100-400mm L Lens  (Read 5840 times)
Andy76
« on: 09 April 2013, 22:12 »
Hi All
I've been dabbling with photography for the last 9 months or so, I'm looking for a lens to use for a bit of wildlife and at motorsport events. I'm using a 600d and currently have an 18-135 lens. I find this is a good general lens albeit not the best quality but a good starter none the less. It meets most of my needs but it struggles with the long range stuff.
Are any of you guys using the 100-400?
I appreciate its quite an expense but from reading the reviews its worth holding out for a good second hand lens. It would also provide an overlap to the 18-135. Would appreciate any thoughts
Offline ajmoir36
Re: Canon 100-400mm L Lens
« Reply #1 on: 09 April 2013, 22:31 »
I have to admit I looked at the 100-400mm (push pull sounds odd, they are dust suckers too) then they released the 70-300mm L (gets good reviews) was considered similar price to the 100-400mm, but bought the 70-200mm L IS USM mk2 and a x2 extender eventually.
I think in the end the F/2.8L won it over and it is a fantastic lens, its the best I own and the pictures are the sharpest I have ever seen. On my 450D then 7D and now 5D mk3. I have to admit I took a massive risk buying in the states on a two week business trip from a camera shop with a $200 dollar instant in store rebate. All in with credit card exchange rates it cost me £1525, but it was the best money I have ever spent on camera equipment.
Diagonally parked in a parallel universe.
On Order: Mk8 R, Pure White, Reversing Camera, Harmon Kardon, Heated seats all round.
Gone: Mk7.5 R, 5dr, DSG, Deep Pearl Black, 18” Cadiz, Nav, Winter Pack, Keyless, Dynaudio and Reversing camera.
Gone: Mk7 R, 5dr, DSG, Limestone Grey, 19" Pretoria's, Nav Pro, DCC, Winter Pack, Keyless, Mobile Prep and Reversing Camera.
Gone: Mk6 GTD, 5dr, Manual, Tornado Red, 18" Vancouvers, RCD510 + Dynaudio, heated seats.
Andy76
« Reply #2 on: 09 April 2013, 22:51 »
I must admit the push pull does put me off, not so much from a using it point of view but the issues with it sucking dust.
I suppose as always it comes down to the balance of quality, versatility and cost. I'm not convinced there would be a substantial cost saving buying a shorter lens with TC but equally as you point out there is the benefit of a faster lens.
Decisions, decisions....
Offline ajmoir36
« Reply #3 on: 10 April 2013, 17:59 »
One question is what body do you have a FF or a 1.3x/1.6x? When I started out I had the 450D with a 1.6x so it was really a 112mm to 320mm, but then again the 100-400mm would be a 160mm-640mm. The range is so much further. Now I have moved to full frame the x2 extender had to be purchased as the 400mm is useful. But I suppose the price difference is £600ish. which is quite a bit, that's nearly another lens.
I suppose as a crop compare
http://www.flickr.com/photos/techie_ali/8637146469/in/photostream
Cropped No extender just the 5D mk3 and the 70-200mm mk2 there was no time for the extender with this shot.
http://www.flickr.com/photos/techie_ali/8478660201/in/set-72157632779270753
Andy76
« Reply #4 on: 10 April 2013, 21:29 »
I'm using a 600d so it's a 1.6 factor. Thanks for posting the pics it's good to see the quality. You have some nice shots on your flickr account too.
I had a quick look at second hand lenses on ebay and there isn't much difference price wise, probably not enough to justify going with the shorter lens and the TC
Offline ajmoir36
« Reply #5 on: 10 April 2013, 23:01 »
Thanks, one thing I do know is good quality equipment holds its value well. Its a bit like an investment.
Offline Diamond Hell
  • Opinions я Us
« Reply #6 on: 11 April 2013, 08:37 »
The slow aperture will frustrate you.  Find a 70-200 F2.8 as cheaply as possible.
Once you've gone F2.8 you'll want the option wherever you are.
Offline DubFan
« Reply #7 on: 11 April 2013, 09:07 »
You could always look at the 70-200 f4 L. Much cheaper than the f2.8 and still L glass. It's also smaller and lighter than the 100-400 L.
My brother borrowed a 100-400 L, it was huge. He carried it around London for a day and got a sore shoulder. It's much less versatile than the 70-200, which can be used for lots of different types of shot (it's even good for portraits). The 100-400 L is more limited by it's focal length and it's weight.
Here's a hot my bro took on the 100-400 L, with a Canon 40D.
I would suggest only going for the 100-400 L if you shoot so much wildlife than you can justify having a lens for just one purpose.
I have a 70-210 f4, and can get great shots at f4. You don't *need* f2.8 (although it's rather nice if you can afford it).
This was at 210mm f4.
berry cold by AlistairBeavis, on Flickr
Andy76
« Reply #8 on: 12 April 2013, 22:38 »
I think the 70 200 f2.8 is probably beyond my means for the time being.
I had been reasonably settled on the 100 400 as I felt it struck a fair balance all round but I am now wondering if I really need the reach. Time for some more research I guess.
Offline DubFan
« Reply #9 on: 12 April 2013, 23:24 »
If that's the case, perhaps you should hire a 100-400 for a weekend to try, then hire the 70-200 to see if it really is too short.
A £50 hire charge is probably worth it if you're going to spend £500-1000 on a lens.
