Author Topic: 4 stud Front-disk Rear-drum to 5 stud disk/disk conversion...  (Read 1408 times)
billabong
Hi Folks,
I have a GTI that i'll be scrapping soon, I also have a 1.9D (1Y) that is 4 stud with rear drums.
I want to convert to 5 stud so was thinking I could use the setup from the GTI?
What would be needed?
Will I need to mess about with the master cyclinder?
Taa
Offline xionsolaris
You could just swap the rear beam over with everything attatched not to sure about the master and braking bias side of things
Offline itavaltalainen
Your diesel might have smaller master cylinder (most likely will have).....
Offline mat-ryder
Swapped all the components on the diesel to 288mm front and standard rear disc setup from a vr6. Only problem that you will face is the rear bias valve if your diesel doesn't have abs. You can leave the rear beam on the car and swap over all of the hubs and calipers etc but may need brake lines made up from the bias valve. Mine was completely corroded and not working anyway so i just scrapped it and left the tdi master cylinder on. I will warn you that it does lock the rears if i massively stand on the brakes in the wet, but for day to day driving its fine. The swap itself isnt that hard as the whole front hub/lower arm/driveshaft from the gti fits straight on, 2 bolts on the lower arm, 2 bolts on the hub and 6 spline bolts on the driveshaft, then obviously the brake lines.
Offline xionsolaris
If it does have abs i still would think it would be a problem unless it runs the same abs pump but im sure its programmed with rear drums on the back and would fail to run a disc braking system im sure it would lock up alot more
billabong
Dont the driveshafts on the 1.9D have 90mm flanges and the GTI 100mm?
