Golf mk4
Wazzzer
Audi tt 225 injecters for my 1.8t???
Topic: Audi tt 225 injecters for my 1.8t??? (Read 5234 times)
212bhprabbit
08 April 2013, 21:27 »
Hi guys I'm debating wether to put audi tt 225 injecters into my 1.8t aum!!Does any1 no if I can??if so is there much power feeling?much love
jonnyturbo
Forum addict
Re: Audi tt 225 injecters for my 1.8t???
08 April 2013, 21:39 »
Yep straight fit . I had them in mine . worth replacing the injector seals while you have the injectors out hth
212bhprabbit
08 April 2013, 21:57 »
Thank you!is there any power difference?
jonnyturbo
Forum addict
08 April 2013, 22:15 »
Yes a lot more power to be had with remapping bigger turbos etc . you can't just stick them in and expect them to work tho
Chris.
08 April 2013, 23:40 »
Will need mapping in.
Whats wrong with your current ones? Good for 270?
Click For Build Thread
248bhp 278lbft R - Tech Powered 1.8T!! - Gone but NOT forgotton
212bhprabbit
09 April 2013, 07:03 »
Nothing's wrong with them but I'm pushing 286 so I wanted more power!!
Dalo Harkin
Reply #6 on:
09 April 2013, 12:12 »
spec?
ARZ K03s, Oettinger Side Skirts, R32 front, Carbon stage 2, Forge 007p (yellow spring), Forge Actuator (yellow spring), Pipercross panel filter with DSG parts, N249 and N112 deleted, SAI deleted, Carbon canister deleted, Rear wiper deleted, Long Life turbo back custom exhaust with 200 cell sports cat, VR6/G60 clutch kit, Creation Motorsport TIP, Catch can, 'Wellycooler', K04 charge pipe, S3 ported inlet manifold - looks pretty standard on the outside though
Ashmond
Money, b!tches And Boost
Reply #7 on:
09 April 2013, 13:01 »
Quote from: 212bhprabbit on 09 April 2013, 07:03
Im interested on where you got that figure from as you would be hard pressed to get that on standard AUM injectors/2.75" maf plus you would be running majorly lean dude. Trust me I used to have an AUM engine with a KO4 on standard injectors for a while....now Im running a KO4 on a stage 2 map, with s3 injectors and im running pushing 281 at last reading.
p.s: if your current injectors are faulty I have a decent set of AUM ones for sale
Last Edit: 09 April 2013, 13:04 by Ashmond
212bhprabbit
Reply #8 on:
09 April 2013, 13:28 »
It's all about the money!!garret turbo!!forge pistons!!custom map by Jk!forge intercooler!port polished!!the list gos on!!
Ashmond
Reply #9 on:
09 April 2013, 14:24 »
Your running a garrett on standard injectors, when you had the custom map they would have told you would would have needed new injectors and a bigger fuel pump...
Golf mk4
Wazzzer
