Author Topic: Cquartz uk on Monza 2's??  (Read 1931 times)
Offline Delboytuk
« on: 08 April 2013, 20:57 »
Hi everyone
Just picked up my 09 plate Candy White  car at weekend.Monza 2 black shadow Alloys are in mint condition and hoping to keep them that way!! Can anyone tell me if I can use Cquartz sealant on them?If not ,what else can I use?
Thanks
Offline Dan J
Re: Cquartz uk on Monza 2's??
« Reply #1 on: 08 April 2013, 21:18 »
Yes definatly :smiley: just make sure you prep them well before applying the coat ie decontaminate by a thorough wash then ironx then a light claying, light polish to prepare the surface then a full proper wipe down with eraser or similar(ipa or panel wipe), you must make sure all surfaces are free from oils etc from polishing or you could have problems with bonding etc, then your coating, they can't get wet though for at least 12hrs after application so it can bond and cure properly, top with reload an hour after application which will protect the coating whilst its curing :wink:
« Last Edit: 08 April 2013, 21:24 by Dan J »
Offline Delboytuk
« Reply #2 on: 08 April 2013, 21:29 »
Brilliant! Thats the answer I was hoping for!!Wasnt sure if I could use Iron x on them too.used this on my last car and its a fantastic product.So , to recap, just wash,use eraser,then apply?
Many Thanks
Del :grin:
Offline Dan J
« Reply #3 on: 08 April 2013, 21:42 »
No matter how mint they look there will be crap there to get rid of trust me, ironx is ph neutral so safe on everything basically.
Give them a good wash with a neutral shampoo if they are just a bit dusty, then ironx,rinse clay rinse and dry off, get some finishing polish or fixer if you've got that and polish by hand, don't have to press hard or anything like that its just to cleanse the surface to get rid of any remaining nastys that could be lerking ;) yes then a thorough wipe down with eraser, apply the cquk thinnly and do a wheel at a time, apply, allow to dwell for a minute or two then wipe of with clean microfibre then onto the next one etc etc.
After an hour apply reload.
« Last Edit: 08 April 2013, 21:50 by Dan J »
Offline Mr GTD
« Reply #4 on: 09 April 2013, 13:10 »
Aye Top advice from the Top Man himself....  :kiss:
Offline Delboytuk
« Reply #5 on: 09 April 2013, 17:16 »
Thanks Dan
Very much appreciated advice.Cheers
