Author Topic: Gunk in coolant and oil  (Read 2899 times)
Offline iain1977
« on: 08 April 2013, 13:09 »
hello folks :-)
I was about to sell my Golf so decided to service it first . I noticed some gunk on the oil cap and in the engine so had a look in the coolant tank and the liquid was quite brown , on dipping a screwdriver in the bottom of the coolant tank had a lot of sludge . I`ve had a look online and got various possible causes from blown head gasket to general dirt/rust coming from radiator , i thought the gunk in the oil could be down to the fact that the car barely gets used and doesn`t cover a lot of mileage when it does , so thought it best to register here and ask in the hope someone else has any info ! the car is a 1999 mk4 gti 2.0 engine code APK , its covered just under 100,000 miles and has been regularly maintained and serviced . it is not overheating at all and runs fine . I hope its not going to cost a fortune to fix but need some advice so i can be armed with some facts when i go to the garage to get a quote . Typical it happens when i`m about to sell the damn thing but i`m glad i noticed so some other poor sod didn`t buy it and get lumbered with the problem .
Offline dom
  • Back in a Mk4
Re: Gunk in coolant and oil
« Reply #1 on: 08 April 2013, 13:42 »
It could just be coincidence and the gunk in the oil is due to short journies and the sludge in coolant is just because the system needs a flush.
That said, it does suggest head gasket to me, especially being the 2.0 :undecided:
Get a compression test done to be sure.
Offline navmk4gti
« Reply #2 on: 08 April 2013, 13:49 »
The 2.0 known to get sludgy under oil cap if driven on a lot short journeys. Give it a wipe and just keep eye on it. As for coolant bottle get new one for tenna and change over. I had a filthy coolant bottle when got my car changed over and just kept eye on it. Its clean and no oil mixing in coolant so all good :wink:
If you see coolant starting get dirty fast and oik mixing then head gasket :lipsrsealed:
Offline iain1977
« Reply #3 on: 08 April 2013, 14:17 »
cheers for the replies guys ;-) the only reason i thought it might not be the headgasket is its never over-heated or anything . i`ll have a look at these options anyway see if any of it helps , not looking forward to a potential huge bill just when i`m trying to sell it :-(
Offline iain1977
« Reply #4 on: 09 April 2013, 13:30 »
Quick question , how much water/coolant does the system hold in total , and what percentage of each should that contain ? going to get a flush done and change the oil see if that helps . and would you recommend using a radiator flush product to try and clean anything stuck in the system ?
thanks ;-)
Offline dom
  • Back in a Mk4
« Reply #5 on: 09 April 2013, 13:53 »
I think it's about 3l, I used a 50/50 mix when I last changed mine.
Offline navmk4gti
« Reply #6 on: 09 April 2013, 14:11 »
Bottle and half of coolant and rest water should see you right. Get coolant from dealers :wink:
Offline Mark b
« Reply #7 on: 09 April 2013, 17:53 »
Mine is a 2L and I've have the sludgy stuff been told its condensation I gave it a wipe but still there a little but just got back from London and gave my car a good blast and seems to be clearing up as I only really do short journeys mainly to work and general running around
Standard gti 2.0 115bhp 2000 w reg
Offline iain1977
« Reply #8 on: 10 April 2013, 14:21 »
nice one thanks for the replies guys ;-) gonna get a new coolant tank and do the flush and an oil change hopefully that`ll clear things up and i can get her sold !
Offline ant_gti
  • mk3 20v turbo
« Reply #9 on: 10 April 2013, 18:20 »
im surprised to see no one has mentioned the oil cooler,does the mk4 2.0 not have one?
