Author Topic: Cam position sensor??  (Read 2645 times)
Offline craigus
« on: 07 April 2013, 21:26 »
Hey all after a bit of info.. Got a mk5 gt tdi 140 and it has the erratic lumpy idle but also when it is up to temp and you turn engine off after about 5 mins it really struggles to start it does start but takes a while.. An sure I read on here a while ago someone say it may be can position sensor.. Was wondering if anyone has had any if the same issues??
Any info greatly appreciated
Cheers Craig
Offline topher
  • Administrator
  • fully functioning
Re: Cam position sensor??
« Reply #1 on: 08 April 2013, 00:29 »
sounds more like a coolant temp sensor issue, or weak battery. to be honest there are quite a few things that could cause what you're describing, needs some diagnostic investigation!
Offline craigus
« Reply #2 on: 08 April 2013, 05:21 »
Had new coolant temp sensor and battery is only 18 month old so am kinda stuck on this..
Offline craigus
« Reply #3 on: 08 April 2013, 05:32 »
Also had new egr valve at local vw specialist and been scanned with vcds a number of times and everything comes up fine injectors and everything so it's kinda doing my head in but he did day it may be cam position sensor on way out...
Offline topher
  • Administrator
  • fully functioning
« Reply #4 on: 08 April 2013, 20:31 »
hard to say without getting my hands on it! you possibly have two unrelated issues. the hot starting problem can actually be mapped out of the ecu in most cases, although 99% of the time i find a hardware fault causing the problem. Lumpy tickover can be down to torsion value (cam timing) out of spec or faulty injector seals/bolts, but again there are plenty of other things that can cause it too.
Offline craigus
« Reply #5 on: 09 April 2013, 11:43 »
ahh right, well other than that it does drive fine so maybe have to get it looked at properly at some point, cheers for the advice though
