Author Topic: Sunroof  (Read 1924 times)
Offline VR6_ROB
  • Mk2 VR6 / Corrado G60
Sunroof
« on: 07 April 2013, 21:04 »
Anyone know how to set these up
It used to work fine talking few years ago now
It opens perfect but when I go to close it
The final stage where the sunroof moves up to seal the roof
It won't go high enough leaving a small gap which leaks
Also when I refitted the wind breaker back on the sunroof won't push it down enough to clear it
What I have tried adjusting bits and pieces but nothing has worked
Offline X4MGS
  • VAG Parts SNOB!!!
Re: Sunroof
« Reply #1 on: 07 April 2013, 21:07 »
Have you tried closing it with the deflector & arms removed??
For More Info Click To See;
Offline VR6_ROB
Re: Sunroof
« Reply #2 on: 07 April 2013, 21:13 »
Yeah I think that's why I took it off to see if it would seal at the other end of the sunroof
And it didn't. it all started when the sunroof opened out of line and jammed so I changed part of the mechanism I even adjusted some brackets that have a raised bit on them as they is another locating slot
To make it more raised
Offline X4MGS
  • VAG Parts SNOB!!!
Re: Sunroof
« Reply #3 on: 07 April 2013, 22:37 »
sounds like the cable or something has jamed it.
might be worth taking it out and starting from scratch..
They are IMO over engineered - but guess thats why they last!!
Offline Steve_B
Re: Sunroof
« Reply #4 on: 08 April 2013, 12:18 »
Is the gap at the front or the back? If it's the back look at the runner bit on the end of the cable that the small bar under tension sits in. It's a black circular bit on a small rod that goes into the plastic housing. If any faults mean the bar isn't under tension the sunroof won't lift up that last little bit.
Hope I've explained it well enough, should be clear when you have a look.
Offline VR6_ROB
Re: Sunroof
« Reply #5 on: 08 April 2013, 18:04 »
I changed the cable after it jammed the first time mate
I'll check that out hopefully that could be the problem it is at the gap but also need to find out why the wind deflector does not lower enough also as I have to leave it off for now which means I can't use the sunroof as it would be loud
Thanks for comments guys ill try update and get some pictures up
