Author Topic: driveshaft boot  (Read 740 times)
Offline Scott D
driveshaft boot
« on: 07 April 2013, 20:39 »
noticed the driveshaft boot on the passenger side has split
can that boot be replaced easily or does the shaft have to come apart?
miffed off spent a fortune on the car recently and was 100% issue free for a week or so  :grin:
2003 1.8T GTI 180 - APR Stage I, S2000 Filter, R-Tech Supersize TIP, Bilstein B12 Suspension, 18" OZ Superleggera, Recaro Heated Leathers, US Spec Rear Lights, N249/SAI/PCV Delete
1.8T AUQ - 241bhp & 286 ft-lb
R-Tech Map, Forge FMIC, SFS Oversized TIP, Ported Manifold, Milltek Turboback non res exhaust, Forge 007p, N249 & N112 delete, SAI delete, S2000 Air Filter, Sachs clutch & Lightweight Flywheel
Offline Granta Gti
Re: driveshaft boot
« Reply #1 on: 07 April 2013, 20:49 »
You could do it in situ but it will be a lot easier taking the drive shaft out.
Offline Steve_PD
Re: driveshaft boot
« Reply #2 on: 08 April 2013, 00:31 »
Buy genuine ones, cheap ones are crap.
Easier to take the shaft off and replace it.
