Author Topic: 312mm brakes  (Read 1976 times)
Offline coolio
312mm brakes
« on: 07 April 2013, 13:15 »
can anyone tel me is the  312mm brakes from mk4 golf is a straight fit onto a mk3 gti 16v model
VW BUSH
Re: 312mm brakes
« Reply #1 on: 07 April 2013, 13:19 »
oh dear
Offline tweed
Re: 312mm brakes
« Reply #2 on: 07 April 2013, 14:15 »
Nope!
You need the carriers and disc then use the 288 caliper and a 6mm spacer I believe
Offline F17BAD
  • Golf MTM S3 GTI TURBO
Re: 312mm brakes
« Reply #3 on: 07 April 2013, 14:56 »
u can use the 312 calliper too, thats what i did but you will need to change the lines too
Not no ordinary GTI....
www.mixcloud.com/kells/
Offline tweed
Re: 312mm brakes
« Reply #4 on: 07 April 2013, 15:14 »
If your gonna do it then use the caliper.
Yes they fit just need 6mm spacer and customs lines.
Offline coolio
Re: 312mm brakes
« Reply #5 on: 07 April 2013, 15:53 »
so where i can get the 6mm spacers and longer bolts from ?
Offline tweed
Re: 312mm brakes
« Reply #6 on: 07 April 2013, 16:21 »
At a metal shop. Make a template and ask them to cut them out. And a local hardware shop. I got a shop near me called powerdrive that have hundreds of different types and strength bolts.
Offline F17BAD
Re: 312mm brakes
« Reply #7 on: 07 April 2013, 17:20 »
We made our own spacers out of stainless steel, use Super high Tensile bolts, cant remember length etc but i got them on ebay for a few quid, i prob still;l have them in my saved list from when i did mine a couple of year ago
Offline coolio
Re: 312mm brakes
« Reply #8 on: 07 April 2013, 18:44 »
it Will be great if u can dig it up for me ,thanks in advance
Offline decksla
Re: 312mm brakes
« Reply #9 on: 08 April 2013, 07:30 »
this is my thread from the Aussie forums
hope it helps.
one last thing to add, if you cut off the brake pad sensors and whack them in, the CEL goes away.
http://www.vwwatercooled.com.au/forums/f47/vr6-312mm-brake-upgrade-questions-81471.html
