Author Topic: Door wiring / installing central locking and remote  (Read 3570 times)
Offline madsb
Hey guys.
Bought an aftermarket kit for installing remote central locking (car doesn't even have central locking atm).
The utterly retarded plugs in the doors that the connections have to run through means that it would be way easier for me to use existing wiring in the door..
I figured that since the wiring looms etc. were all mass produced, there'd be unused wires that I could use.
So, if anyone knows what the wires in the following pictures are used for, I would greatly appreciate it :)
1:
2:
(the ones in the U-145 plug)
I know for sure, that neither of them can be the wires for interior lights when door is open, as I've tested for this.
So what can they be? My car doesn't have an alarm either.
The text on the second picture says immobiliser, which the car has, in Danish - could it be something related to this? Or is it simply proof, that the car has it? Didn't think the immobiliser did anything to the doors.
Cheers.
Offline madsb
Re: Door wiring / installing central locking and remote
« Reply #1 on: 07 April 2013, 13:15 »
Really need some help here fast, guys.. Would like this done before the end of the day:))
Offline itavaltalainen
« Reply #2 on: 07 April 2013, 14:55 »
get a multimeter and a haynes manual with wiring diagrams....
can't understand why you'd go for aftermarket central locking.... get original from VW and a remote FOB controller....
probably costs the same.
Offline madsb
« Reply #3 on: 07 April 2013, 20:45 »
Multimeter won't tell me if it's used for anything or what.
Couldn't find oem central locking .. this one was like 30 quid delivered anyway and had both solenoids and remote fob
Still would really appreciate if anyone knew what they are for..
cheers.
Offline boneybradley
  • Back in a Mk3...
Offline madsb
« Reply #5 on: 08 April 2013, 09:12 »
Thanks but can't really make much of it..
Going to the local vw garage to ask them today :)
Offline vr6D4v3
« Reply #6 on: 08 April 2013, 10:27 »
Look in the boot, near drivers side rear cluster and look for the central locking pump. You can do all of your wiring there, plus be able to see if you have cl or not.
Offline madsb
« Reply #7 on: 08 April 2013, 19:32 »
Thanks for the tip man. Basically this was what I did earlier at the dealer... Turns out there was central locking all along, one of the previous owners decided to f**k it up somehow though.... Alot of the wires by the pump have been spliced, and I can't make out what to do. Not sure what the guy has done..
Seeing as I'm already half way through with installing the new central locking, I guess I might as well finish it lol ... Now I have both a non-functioning central locking pump and aftermarket solenoids haha..
Cheers guys.
« Reply #8 on: 08 April 2013, 20:23 »
fix the original pump....
easy to fix... can give you a wiring diagram if you need (email me)....
much better than a solenoid aftermarket solution.
  • Back in a Mk3...
« Reply #9 on: 08 April 2013, 20:49 »
or better still a new pump and a section of the wiring.. I have a feeling the pump has broken (most likely a leaky pump or a split air wire?) and both will drain the battery as the pump will keep running as it can't register the air pressure correctly, and to solve they have chopped the wires rather than investigate a repair
