Author Topic: Project Corrado 1.8T  (Read 38698 times)
Offline Ferdinor
Re: Project Corrado 1.8T
« Reply #10 on: 07 April 2013, 15:50 »
Good luck chasing down boost leaks as well I  count 9 or 10 joins from the ic to turbo  :lipsrsealed:
Well how would you or anyone else get from there to my intercooler using less joins?  :huh:
yes i could weld a solid pipe before anyone says anything..... but any other options?
Offline F17BAD
  • Golf MTM S3 GTI TURBO
« Reply #11 on: 07 April 2013, 17:10 »
change that pipe off the turbo, its too high for this application , what mounts u using ? iv used same oem pipe in a mk2, used a mk3 subframe.  also used it in a mk1 and that was not high like yours :undecided:
also, smoothed bays always crack.. :sick:
Not no ordinary GTI....
www.mixcloud.com/kells/
Offline dom
  • Back in a Mk4
« Reply #12 on: 07 April 2013, 17:59 »
Like this:
Offline Ferdinor
« Reply #13 on: 07 April 2013, 19:22 »
I used the pipe of the original because thats all i have and being a budget project all i can afford atm, i will mount it using the original mount to help support it, if it doesnt work i can always change it
Like this:
I would love to have the money to go out and buy the perfect forge pipes but atm i dont so i guess i will stick to my boost leaks  :wink:
Offline dom
  • Back in a Mk4
« Reply #14 on: 07 April 2013, 19:41 »
The only forge pipe there is the one that goes into the TB, the rest are from here: http://myworld.ebay.co.uk/mrsilicone
Offline Ferdinor
« Reply #15 on: 07 April 2013, 22:00 »
Thanks for the link i had already seen there pipes when i was having a browse earlier, i will have to see if i can make the run a bit smoother :smiley:
Offline tech1889
  • Mk2 GTI FTW !!
« Reply #16 on: 07 April 2013, 22:24 »
Looking good mate i personally like the smoothed bay look
Offline Ferdinor
« Reply #17 on: 07 April 2013, 22:36 »
Cheers, i have always liked smoothed bays and always wanted to do it, if it cracks then i will have to work out a way around it but for now im happy with it  :smiley:
Offline tech1889
  • Mk2 GTI FTW !!
« Reply #18 on: 07 April 2013, 22:41 »
The problem is with our roads its unlikely to last forever but if there are flexible joins then you should be fine.. Keep us posted
Offline F17BAD
« Reply #19 on: 07 April 2013, 22:50 »
This is how we do them using the very same metal OEM pipe from the Turbo
much cleaner look than the faffy looking bay Dom posted up
done this on a mk2 and a mk1 too where they have had KO3 and KO3S turbos
