Author Topic: Questions about my sloppy knob :|  (Read 1845 times)
Offline AD1.8T
« on: 06 April 2013, 21:31 »
Sooo when my cars in gear its abit sloppy nothing major but if i can improve it i will !
Sooo the question is awesome have these 2 parts for sale that im hoping will do the trick
42DD shifter bushings i know how to replace these well i think i do lol
And this thing that goes at the bottom of the gear knob i haven't properly looked but ive noticed it before....  I can safely say i dont have the foggiest how to replace it !  :laugh:
Has anyone replaced the 2 and saw a decent difference?
Please dont go recommending a quick shift as its not that thats the problem its the side to side movement and general worn feel !
Offline navmk4gti
Re: Questions about my sloppy knob :|
« Reply #1 on: 06 April 2013, 22:11 »
There is small bushes down there somwhere which aparently is the reason for wobbly gear knob. I was going to replace them on my gti but then 3 years passed :lipsrsealed:
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Offline GTi_James
« Reply #3 on: 07 April 2013, 20:54 »
i have one of them, havent fitted it yet but drove a mates who has it fitted and it is a major difference, doing this when i fit the 3" ebay special  :grin:
Offline Scott D
« Reply #4 on: 07 April 2013, 21:09 »
shifter bushes do seem to have a bit of play in them even from new
had a look at getting a diesel geek short shifter a while back that should tighten up feel a lot but expensive.
those 42 draft design bushes should do the same as well
2003 1.8T GTI 180 - APR Stage I, S2000 Filter, R-Tech Supersize TIP, Bilstein B12 Suspension, 18" OZ Superleggera, Recaro Heated Leathers, US Spec Rear Lights, N249/SAI/PCV Delete
1.8T AUQ - 241bhp & 286 ft-lb
R-Tech Map, Forge FMIC, SFS Oversized TIP, Ported Manifold, Milltek Turboback non res exhaust, Forge 007p, N249 & N112 delete, SAI delete, S2000 Air Filter, Sachs clutch & Lightweight Flywheel
Offline AD1.8T
« Reply #5 on: 07 April 2013, 21:37 »
Good to know to be fair there that cheap its worth a punt !
Wazzer cheers for the link but i can honestly say ..... Not a fooking clue what is going on in that how to lol care to explain :D
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #6 on: 07 April 2013, 23:39 »
One of the pics shows you where the pivot bush fits (which is the one you don't know about)
Offline AD1.8T
« Reply #7 on: 08 April 2013, 08:28 »
God i hate not knowing stuff ! So its just the couple of torx bits on the gold plate thing pop the bush out job done ? I presume the other bits dont apply to me? Dropping the exhaust ect ?
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #8 on: 08 April 2013, 13:07 »
Yeah you should be able to pull the gearknob up enough to get the pivot bush out
Offline AD1.8T
« Reply #9 on: 08 April 2013, 14:54 »
Sweet cheers for that bud ! Im currently future proofing everything so when it gets mapped it doesnt cause problems/fall apart !
