Author Topic: Grrrrrrr....  (Read 1794 times)
Offline hardmonkeys
Grrrrrrr....
« on: 06 April 2013, 20:34 »
So..this is how my weekend has been so far!!
Finish work on Friday with all intention of doing rear discs and pads, give myself a weekend..no probs! Dne one side, slightly sticky piston...overcome that, done! Pads in, new disc on!
Do other side..have problems with another sticky piston, unwind tool slips, and a brake pipe snaps :angry:
Ok..so I buy a new caliper today, new brake pipe, brake fluid also.
Finally plumb in the new pipe after a difficulty, excellent I'm thinking! Lets put new caliper on, get the pads in before it gets dark! Should be the easy but now,  :laugh: :laugh: :laugh: hahaha...NO!! Sliders on the carrier not doing there job, and not sliding, attempted to get them moving, pull seal back, grease the bad boys up, put a 15mm spanner on the end, give it a wiggle...SNAP!!! now need a new carrier!!   :cry: (or do I?? Please tell me if not)
Attempt to remove carrier...one bolt comes out fine...bottom one seized!!!!! Now it's dark, and I gave up...not before dousing it in WD40 first...
Tomorrow is a new day!!!!
'05 VW Golf Mk V GT TDI Laser Blue
'98 VW Golf Mk IV GTi Black
'97 VW Golf Mk III GTi
'58 VW Golf Mk V GT Sport TDI Steel Grey
'10 Audi A4 B8 SE Multitronic
'00 VW Golf Mk III.V Cabrio
'12 Audi A5 S Line Black Edition
'03 VW Golf V6 4motion
MK3.5 Cabrio 2.0 8v Automatic to 2.0 16v Manual Conversion Project
http://www.golfgtiforum.co.uk/index.php?topic=272728.
www.dorsetautorestore.co.uk
Offline xionsolaris
Re: Grrrrrrr....
« Reply #1 on: 06 April 2013, 21:29 »
I thought u dont need to remove the carrier on mk4s to remove the rear disc as it just pops out
Offline hardmonkeys
Re: Grrrrrrr....
« Reply #2 on: 06 April 2013, 21:46 »
You don't..but putting the caliper back on the carrier, the sliders were seized, so with the new pads in, the caliper never went on right...plus, with them seized, the pads wear down quicker
« Last Edit: 06 April 2013, 21:49 by hardmonkeys »
Offline gm8
Re: Grrrrrrr....
« Reply #3 on: 06 April 2013, 21:51 »
you can buy the slider pins seperate i am sure, can you get mole grips on the bit of the pin that broke ?
as for the carrier bolts its an 8mm allen bolt  (i think ) make sure the allen bit is fully seated and get a breaker bar on it.
Offline hardmonkeys
Re: Grrrrrrr....
« Reply #4 on: 06 April 2013, 21:55 »
No..I tried :-/
Offline hardmonkeys
Re: Grrrrrrr....
« Reply #5 on: 07 April 2013, 15:56 »
Old carrier off  :smiley:
Waiting for my new one...
