Author Topic: MK2 Valver - what grade of oil ??  (Read 4582 times)
Offline ...joe
Re: MK2 Valver - what grade of oil ??
« Reply #10 on: 02 August 2005, 16:00 »
sounds good, you've got mail!!! :wink:
mail@trimdeluxe.co.uk
www.facebook.com/Trimdeluxe
Offline Redbaron
« Reply #11 on: 02 August 2005, 19:37 »
100 degrees perfectly normal aint it?
 :sad:
Offline monzablue16v
« Reply #12 on: 02 August 2005, 21:44 »
Bloody hope so!! :)
Offline Redbaron
« Reply #13 on: 02 August 2005, 22:41 »
So do I lol!
Mine has hit 120 when thraping on motorway but 98-108 is normal when driving lanes and stuff.
MFA is a load of bollocks anyway.
32.1 mpg my arse! I worked it out at 24.5
Offline davidhawkins_78
  • Valver Bad Boy
« Reply #14 on: 03 August 2005, 08:41 »
Well I'm new to the 16v engine, so maybe I'm wrong !
My 8v would always been around 90 Degrees from normal driving - sure 120 degrees would pop up on a good tonking though  :grin:]
I'll hold fire on that oil change then as it's not due for one, I just thought the high temp was a sign she's carrying sh*t oil !
'89 Monza Blue Valver
to quote a VW engineer, "the Mk1 was the prototype, the Mk2, the real thing!"
« Reply #15 on: 05 August 2005, 00:06 »
do it anyway mate if you don't know how good it is worth an hour ;)
You getting a respray the same colour? been thinking of doing mine but think I'll add some more metallic flecks for that glinty custom look! no big chav chunks tho!!! just vag metallic!
Offline Agreeable Slick
  • Unit
« Reply #16 on: 05 August 2005, 04:27 »
synta silver, and a genuine vag filter.
100 degrees is fine, as long as it doesn't go above the mid 20s and stay there then you will be ok, i personally would never run my engine hotter than 124-5 (although the current engine has never actually gone above 102 even uinder heavy load) A fresh oil change and new filter will sort it out a treat, oh and also as its a non return valve should keep the tappets happy as they will never completely dry out again.  :cool: :cool:
Offline rowlers
  • I'm back - MK7 GTI
« Reply #17 on: 05 August 2005, 08:02 »
I've read on another forum that synta gold is better for a valver?
I've silver in mine at the mo, and it runs great, no more noisy tappets!!
Whats your thoughts on SYnta gold for a valver then???
  • Unit
« Reply #18 on: 05 August 2005, 13:20 »
Gold is a bit too high grade for a valver tbh, its just not viscous enough. Its generally used in the high end performance engines I.E. 1.8Ts and R32 engines, i would personally stick too silver unless you are confident that the gold is going to do a good job in your engine.
Judderi
« Reply #19 on: 05 August 2005, 15:27 »
Do you have to specificly ask for a filter with a non return valve from vag or are all the vag filters for the valver fitted with the valve?
