Author Topic: N75 valves questions  (Read 1244 times)
Offline welshdean
« on: 05 April 2013, 23:05 »
I've been asking someone questions about there 1.8 T
They told me that vag com showed the n75 mid reading
They then said they replaced it and I asked what we're the problems he was experiencing
And this is what he said...
The car wasn't boosting correctly and it was ranging from 5psi - 12psi and anywhere inbetween. Since replacing it, it now stays at 9 psi but claims it could be down to the forge tip, green panel filter and car back exhaust.
My question to you all is....
Does this sound correct as I've looked on the net and it tells me that the standard is 7 psi.
Or does something not sound right ?
Please help as I'm very interested in this car
Offline Scott D
Re: N75 valves questions
« Reply #1 on: 06 April 2013, 00:02 »
is it an AUM or AUQ?
9-10psi is what mine is holding on a standard AUQ map which is normal iirc.
see if specified vs actual boost can be checked on vag com, sounds ok though if it's holding boost across the rev range.
« Last Edit: 06 April 2013, 00:17 by Scott D »
2003 1.8T GTI 180 - APR Stage I, S2000 Filter, R-Tech Supersize TIP, Bilstein B12 Suspension, 18" OZ Superleggera, Recaro Heated Leathers, US Spec Rear Lights, N249/SAI/PCV Delete
1.8T AUQ - 241bhp & 286 ft-lb
R-Tech Map, Forge FMIC, SFS Oversized TIP, Ported Manifold, Milltek Turboback non res exhaust, Forge 007p, N249 & N112 delete, SAI delete, S2000 Air Filter, Sachs clutch & Lightweight Flywheel
Offline nickellis1
« Reply #2 on: 06 April 2013, 15:27 »
My ecu doesn't read actual vs requested boost as its only a me3.5 so it shows injection timing as actual vs specified but everything on vag com was meeting requested bud
Offline GTi_James
« Reply #3 on: 06 April 2013, 15:52 »
well i just drove down to basingstoke andback with a nice little goodey  :evil:
if you put your foot down it should peak at about 12 then lefel off to about 6-7 and when cruising at 70 should be on 0 mark, if its holding that amount of boost then thats awesome, ask him to lift the engine cover to check the code ,should be on a little silver ledge close the carbon canister and whilst your at it check for any oil marks etc, be a good indication that theres a loose vac pipe etc
Offline nickellis1
« Reply #4 on: 06 April 2013, 15:59 »
I'm the owner, I replaced the valve got it on vag com and all is good again, as I mentioned above My ecu doesn't read actual vs requested boost its only a me3.5 model ecu so it shows injection timing as actual vs specified but everything on vag com was meeting requested, oh and it's an agu,
Offline GTi_James
« Reply #5 on: 06 April 2013, 16:33 »
well there you go and its a solid engine  :wink:
Offline Chris.
« Reply #6 on: 08 April 2013, 00:45 »
Log maf and n75 and you get a good idea!
Click For Build Thread
